Main Movie-- x%
    Other Main Movie-- x%
    Click image for larger version  Name:	for dvdfab.jpg Views:	3 Size:	19.2 KB ID:	357664
    I have been using DVDfab Version 8 for years and have just downloaded Ver10.
    When I copy a movie, usually "Main Movie", I sometimes get xxxxMB 75%. (or some other percentage.) What is being reduced by the percentage? Quality? Extra features like bios of actors, or ???
    Thanks a lot! Rick
    That is the percent of the original selected from the disc. 75% is compressed by 25% and should be no problem.
      As with v8 you can set DVDFab DVD Copy for no compression by clicking on the wrench icon. Please follow the suggestions linked in my sig for using images in posts, your jpg was too small to view clearly, pngs work better.
Name:	1-011 FABADVANCED.png
        Suppose there is no wrench? I kept thinking I was doing something wrong, because I couldn't seem to make the software save my movie on my hard drive. Now I know; there is no wrench, and that's where that particular setting is to be found.
          Please take a screenshot of how it shows on your end and post it here.
          To save the movie to your hard drive, you can click on the folder button next to the SAVE TO field to select a path.
