Checksum not matched on 11.0.0.2 64 bit
    The 32 bit checksum matches but I can't get a match on the 64 bit - version 11.0.0.2 (using a PC)
    The SHA-1 doesn't match either
      Same thing, but I installed the wrong checksum x64 to test it and it installs and seems to run OK, but I have not tested it extensively. I will check further.
      MD5: c68dcb27a6dca78484783f8a709aa627 is what my x64 installer produces.
        Please re-download from dvdfab.cn.
