Save to folders
    Save to folders
    Hello,
    In all versions I have updated, there was always a folder for Main movie and Full movie in the drop down box to save to.
    In Ver 11, the save to only has the option of saving to dvdfab11, iso, movie server, or to one of my burner drives.When I click on the dvdfab 11 folder, there is a BD info, log and temp folders available. How do I get main movie and full disc folders back.I thought these were always there by default in other versions.
    Saving to source drive works well, but sometimes I like to save the disc in Main movie or Full disc.
    Am I doing something wrong here?
    Thank you for any advice.
    Hi tmagz,
    The way folder outputs are written is controlled by a setting in DVDFab. I think the default may have been changed in v11, but you can easily set it any way you like. See the capture below. Note that the Save To options will be blank if you do not have a Source loaded.
Name:	1-011 OUTFOLDERS.png
      Thanks Signals, all is good now.
