Avatar
    Other Avatar
    HI;
    Looking in Fab forum settings but can't find how to attach avatar can someone help me thanks?
    From where you see your username in the upper right corner of any forum page, select My Profile from the drop down selector. From the page that opens, hover your mose over the existing generic avatar so that the Edit Avatar appears and click it, then just follow the prompts. PNG images work best but jpg is also accepted. The allowed size is 80x80 pixels, better to resize it in your image software before uploading it, the forum will shrink it to fit but it will look ragged in some cases.
    Click image for larger version  Name:	1-011 EDITORADDAVATAR.png Views:	1 Size:	20.1 KB ID:	362608
