Can DVDFab extract subtitles only?
    I converted "Shark night" from its BD to MP4 but forgot to set the subtitles. Is there a way to extract only the subs from the BD with DVDFab?
    DVDFab doesn't support to extract only the subs from the BD, you can use other tool to do it.
      Thank you.
        Updated to 11.0.4.0 and it read:
        New: Added the support to extract the subtitles of DVDs/Blu-rays/4K Ultra HD Blu-rays using the OCR (Optical Character Recognition) technology and then output them as standalone SRT subtitle files in the Ripper modules (Advanced Settings > Subtitle Mode).
        New: Added the support to extract the subtitles of DVDs/Blu-rays/4K Ultra HD Blu-rays using the OCR (Optical Character Recognition) technology and then remux them as SRT subtitles when choosing MP4 and MKV conversion profiles in the Ripper modules (Advanced Settings > Subtitle Mode).
        Now it seems I can solve my problem, right?
          Your request is to "extract only the subs", but it will output a video file plus standalone srt file(s), so it does not solve this problem.
            Paultx,
            It does not put out only the sub files, as Mona said, but the subs are in a different file than the video, they are not muxed together.
