I occasionally do 2 copies of some movies, but over the last 4-5 updates every time I select 2 copies dvdfab will only do one at a time. This means having to do the whole process twice. This make the whole process very slow If we can no longer do the multiple copies can you remove the option from the skin cheers
NO Multiple Copies
Please attach a DVDFab internal log and burn log file of an instance where >1 copy was not completed correctly.
As a workaound, note that you can always write the output to an ISO and then use the burn/clone mode or even standalone ImgBurn to burn multiple copies.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
