After creating a custom menu in dvdfab 11 and then running the copy of the movie with the custom menu there seem to be a problem in the upper left corner of the main menu that has the name My Blu-Ray in that corner.
How do you remove the name My Blu-Ray from the main menu in dvdfab?
(((Wilson.Wang DVDFab Staff reply
Edit the text and delete it from the menu, thanks!)))
The My Blu Ray name does not show up when you are doing the custom main menu .
It show up after you copy the movie and custom menu.
