Can MP4 be converted or copied to a DVD disk using DVDfab to watch on TV?
Purchased Season 8 and they sent my wife 6 2GB files to download (mp4).This is what it says: Game Of Thrones S08E01.mp4
Video (.MP4)
As with all media formats, video formats run the spectrum between high quality and low file size. Lossless compression for video files attempts to reduce the file size by removing redundancies. Lossy compression schemes reduce filesize by discarding data without the viewer noticing. The Advanced Video Coding (AVC) standard is one of the most commonly used formats for recording, compressing, and distributing high definition video. File extensions for files produced by AVC are .mp4 and .m4v.
Can these files be downloaded to a folder and be able to use DVDfab to copy them onto a DVD disc ? If so can you give me the right way to do it using DVDfab or do i need another program to convert them and what format do I convert them to ?. Please RSVP
Video (.MP4)
- File size: 1.62GB
- Uploaded: 2019-06-24 12:05:11
