Question on disc's
    Question on disc's
    I've not been able to copy the movie MIDWAY. I kept having trouble so I deleted DVDFab and reinstalled it. This time when I went to copy I put the original in and on the Task Queue Manager the Source said MIDWAY, Option said DVD Copy (main movie) but the Output said 9. This was a regular DVD not a bluRay. Why would it say 9 instead of 5?
    Thanks,
    Ernie
    with the disc loaded, click on the little wrench icon "Advanced Settings"
    there you can click under output the DVD5 option
      Post problems like this in the DVD Copy forum in the future and include the DVDFab internal log session for discs if you encounter a problem.
      This is a long movie with large audio streams, DVD 5 size may be pushing it on compression in terms of video quality. Tell DVDFab to remove the HD Audio unless you really want it, which will save bits for the video stream.
