ac3?
    ac3?
    Hello, is there a way to keep an ac3 identical to the source (features) if present? and then just edit those audio files that aren't ac3? and in case you have a dts 2.0 you can make it an ac3 2.0 without altering it having in the source a dts 5.1/dts hd but 5.1/7.1 which is rendered an ac3 5.1. thanks
    Do you mean in the Copy module or the Ripper module?
      ripper module e converter module.
        alternatively insert, when possible, the ability to extract the audio separately and not only one at a time as in ripper audio but all together those chosen (as for subtitles in srt) at the same time that you extract the video.
