Problem for rip Blu Ray
    Hello,
    I have a lot of Blu Ray how are impossible to rip ,
    I put them in the drive ....but DVD Fab dont see the Blu Rays ???? The Blu Rays work perfect in the ps3
    Movie name :
    Underworld 3
    Hulk
    Silent Hill
    Halloween 2
    The transporter 3
    30 days of night
    Number 9
    the last airbender
    i also start rip TV show Friends from new Blu Ray box ...after rip 5cd (2seasons)now it says unknown error ,plz check if there is a New version of dvdfab.....
    what Can i do ??
    You need to send logs to Signals or Mona so that they can further investigate. I am pretty sure you are new here. It is anybody's guess what is causing the problems you are facing (without logs). Check this link. It is old but it should still work. Scroll down and read Signals' post. He is the maestro here.
    Do the same. Insert the disc. Let the program do its thing. When or if it fails, find the logs.
    Read this: https://forum.dvdfab.cn/forum/softwa...532#post263532
    P.S. For some reason, the link above didn't work! Just copy and paste.
    [admin note: fixed link]
      I clic open log files in the menu ...what is the exact file name , because i have a lot of text files on the page ...(windows 10) , is it the : xdisc text file ?
      I have :
      Libimg
      Install
      Fabcheck_internal
      Dvdfab internal
      Dvdfab core
      Dvdfab ai
      Burn internal
      Ai analyze
      Xdisc
      This are all texte filles ,why the file have not name like :internal error...
      So Can you give me the exact file name how are the error inside plz
        All the logs will be sent if you upload them, the main one needed for each disc that will not open is the DVDFab internal one. You can attach them to a post or upload them, if you upload, post the Log ID numbers that are assigned. Please read the post in the link skoy kindly provided.
          Hi Ralf67, please try again. If still have a problem, please post your feedback ID after you send the log file via DVDFab. We will check for you. Thanks.
