Drag and drop
    Virtual Drive Drag and drop
    Why DVDFab Virtual Drive won't accept a folder or a file by doing drag and drop ?
    You can right-click on the source and then choose "Mount to xx(drive letter):" to proceed.
      Thank you for this info, however, the option to "Mount to xx(drive letter):" doesn't appear in the menu context, Looks like the Virtual extension for explorer isn't integrated.
        While you create a folder output, be sure to create a .miniso file, then you can use Virtual Drive to mount it for playback.
          That's the point if I use the function Make .miniso Image and drag a folder containing a full BD, the dialog box remain empty, the drag and drop doesn't complete the action to create the image. After the drop the line remains empty, but it works with the open folder option to the right. Anyway not a big deal, just annoying to see that the drag and drop function doesn't work anymore, and the mount drive from the contextual menu doesn't appear anymore as well
          see attachments (in french....)
          Cheers
            Hello Mona,
            Any clue on how to fix this issue ?
            Thank's
              Cheers
              Unfortunately your attachments are illegible and have been deleted. Please follow these guidelines for using images in posts https://forum.dvdfab.cn/forum/dvdfab...sts#post349829
