Which product to use for decreasing size of file?
    Purchase Problem Which product to use for decreasing size of file?
    Hi all,
    thx for taking a look at my question.
    I already own;
    Blue-ray to dvd
    Blue-ray recorder Ripper
    Blue-ray ripper
    Dvd copy
    Dvd ripper
    I am setting up a media server with limited HDD space. I'd prefer to store my already owned dvd/blue-ray's in a smaller size, under 2GB preferably. Which tool should i use? Or should i buy different tool? If so which one?
    I don't have expectation of high quality playback with the lower size.
    Ripper can help you convert the DVD/Blu-ray into small size video files, like MP4, MKV, you can pick a profile to have a try first.
Name:	choose profile in Ripper.png
      I think you will be pleased with the results with Ripper, it looks very good, especially with a Blu-ray source.
