DVDFab Auth Offline?
    I cannot open DVDFab on my machine as it can't login, and I can't log onto the members section of the website. I even tried to see if I could upgrade my products, entered my email address, and it didn't work. Anyone know if there is a known outage?
    More likely a false positive on a firewall or antivirus. I will try it later and update here.
      Ok I can log in on my phone if I disconnect from my wireless. Seems that no machine can log into the dvdfab website, and the machine I am using dvdfab on doesn't log in to launch the software. How can I test my connection to the auth front end? What is the url? I want to see where I am getting blocked.
        I figured it out, I had country block turned on in my firewall, and that was getting in the way.
