layer break using imgburn
hi all, dont know if this is the right place for this but here goes, i have a jvc dvd player and a panny blueray player, when i play any original dvd in the jvc player you never notice a layer break it looks seamless, but playing original dvds in the panny you do notice the layer break, so my question is when i burn my dvds with imgburn can i tick the seamless option instead of the layer break option and will the burnt dvds play ok in the jvc dvd player, not fussed about using the panny for dvds. ps. meant to say i would be using verbatim dvd+dl discs. thanks in advance. pps. this is a great forum for newbies like myself.
Tags: None
Well the only thing I can say would be to try it and see. ImgBurn also gives you a selection of spots to select for the layer break where it would not affect the movie as well. Test this out as everyone uses different DVD players and it would be sometime till someone with the same as you would be able to reply. Then again how can someone reply that would have the same DVD player when you not post the model # of the DVD player
Agree with AGJ, this depends on whether or not your player can handle seamless...I'm guessing it can.
You'll have to try it. If it fails you're only out 1 disc anyway.
It'll take the laser just a bit longer to refocus when going from L0 ---> L1 and whether or not this is noticeable will depend on your player,
but you don't want to create a layer break in the middle of an action scene.
Your best bet would be to click on the Preview Selected Cell and take a look.If it ain't broke, don't fix it!
thanks AGJ and maineman for the quick replies, yep meant to say in my post that the jvc dvd players model number is an NX-F3 which upscales dvds to 1080p does do a pretty good job of it too. i'll try your suggestions out on my next burn, as you said maineman it might only cost me 1 disc, i'll post back my findings and let you know. thanks again. flashgordon.
hi all again, copied the movie 2012 to my hard drive with dvd fab using the full disc mode which seemed to go ok for burning to a dual layer disc, then went to burn with imgburn and when it asked for to pick the best layer break position i think it came up with 5 or 6 positions but didn't show any best position, none of the stars at the bottom were highlighted, i proceeded any ways and started of ok but a few minutes after "the cycling tray before verify" stage i got an error which said "failed to read sector 1976
Especially with Full Disc, UNcheck the box that says Remove Layer Break in DVDFab Common Settings. It is on the Protection page. I doubt a bad layer break choice caused a burn failure though. Attach the imgburn log from the session where you got this failure. Have you tried the disc in a player?Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
hi all again, copied the movie 2012 to my hard drive with dvd fab using the full disc mode which seemed to go ok for burning to a dual layer disc, then went to burn with imgburn and when it asked for to pick the best layer break position i think it came up with 5 or 6 positions but didn't show any best position, none of the stars at the bottom were highlighted, i proceeded any ways and started of ok but a few minutes after "the cycling tray before verify" stage i got an error which said "failed to read sector 1976339 and sector 1976340" reason L-EC uncorrectable error. if someone could help me with this i would be grateful. the log is below (i hope) thanks in advance. flashgordon.ImgBurn Version 2.5.1.0 - Log
; Thursday, 22 April 2010, 11:47:22
I 10:41:37 ImgBurn Version 2.5.1.0 started!
I 10:41:37 Microsoft Windows XP Home Edition (5.1, Build 2600 : Service Pack 2)
I 10:41:37 Total Physical Memory: 1,046,956 KB - Available: 563,604 KB
W 10:41:37 Drive E:\ (FAT32) does not support single files > 4 GB in size.
I 10:41:37 Initialising SPTI...
I 10:41:37 Searching for SCSI / ATAPI devices...
I 10:41:37 -> Drive 1 - Info: SONY DVD RW DW-Q31A LYS2 (F(ATA)
I 10:41:37 -> Drive 2 - Info: SONY DVD-ROM DDU1615 FYS2 (G(ATA)
I 10:41:37 Found 1 DVD-ROM and 1 DVD±RW!
I 10:44:51 Operation Started!
I 10:44:51 Building Image Tree...
I 10:44:51 Checking Directory Depth...
I 10:44:51 Calculating Totals...
I 10:44:51 Preparing Image...
E 10:45:12 Operation Aborted! - Duration: 00:00:21
I 10:49:32 Operation Started!
I 10:49:32 Building Image Tree...
I 10:49:49 Checking Directory Depth...
I 10:49:49 Calculating Totals...
I 10:49:49 Preparing Image...
I 10:53:56 Using Layer Break LBA: 1658649 -> 1976160 (VTS_01, PGC: 1, Chapter: 17, Cell: 23, Vob/Cell ID: 3/18, Time: 01:18:19, SPLIP: Yes -> No)
I 10:53:56 Checking Path Length...
I 10:53:56 Contents: 118 Files, 2 Folders
I 10:53:56 Content Type: DVD Video
I 10:53:56 Data Type: MODE1/2048
I 10:53:56 File System(s): ISO9660, UDF (1.02)
I 10:53:56 Volume Label: 2012
I 10:53:56 IFO/BUP 32K Padding: Enabled
I 10:53:56 Region Code: 1, 2, 3, 4, 5, 6, 7, 8
I 10:53:56 TV System: PAL
I 10:53:56 Size: 7,443,075,072 bytes
I 10:53:56 Sectors: 3,634,314
I 10:53:56 Image Size: 8,094,351,360 bytes
I 10:53:56 Image Sectors: 3,952,320
I 10:54:24 Operation Successfully Completed! - Duration: 00:04:52
I 10:54:24 Operation Started!
I 10:54:24 Source File: -==/\/[BUILD IMAGE]\/\==-
I 10:54:24 Source File Sectors: 3,952,320 (MODE1/2048)
I 10:54:24 Source File Size: 8,094,351,360 bytes
I 10:54:24 Source File Volume Identifier: 2012
I 10:54:24 Source File Application Identifier: IMGBURN V2.5.1.0 - THE ULTIMATE IMAGE BURNER!
I 10:54:24 Source File Implementation Identifier: ImgBurn
I 10:54:24 Source File File System(s): ISO9660, UDF (1.02)
I 10:54:24 Destination Device: [0:0:0] SONY DVD RW DW-Q31A LYS2 (F(ATA)
I 10:54:24 Destination Media Type: DVD+R DL (Disc ID: MKM-003-00) (Speeds: 4x, 6x, 8x)
I 10:54:24 Destination Media Sectors: 4,173,824
I 10:54:24 Write Mode: DVD
I 10:54:24 Write Type: DAO
I 10:54:24 Write Speed: 4x
I 10:54:24 Link Size: Auto
I 10:54:24 Lock Volume: Yes
I 10:54:24 Test Mode: No
I 10:54:24 OPC: No
I 10:54:24 BURN-Proof: Enabled
I 10:54:24 Write Speed Successfully Set! - Effective: 5,540 KB/s (4x)
I 10:54:24 Optimal L0 Data Zone Capacity: 1,976,160
I 10:54:24 Optimal L0 Data Zone Method: IFO Cell Boundary
I 10:55:26 Set L0 Data Zone Capacity Succeeded!
I 10:55:27 Filling Buffer... (40 MB)
I 10:55:27 Writing LeadIn...
I 10:55:29 Writing Session 1 of 1... (1 Track, LBA: 0 - 3952319)
I 10:55:29 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 3952319)
I 10:55:29 Writing Layer 0... (LBA: 0 - 1976159)
I 11:07:30 Writing Layer 1... (LBA: 1976160 - 3952319)
W 11:12:01 Waiting for buffers to recover... (LBA: 2674496)
W 11:12:15 Waiting for hard disk activity to reach threshold level...
I 11:12:24 Writing Sectors...
W 11:15:00 Waiting for buffers to recover... (LBA: 3090208)
W 11:15:07 Waiting for hard disk activity to reach threshold level...
I 11:15:12 Writing Sectors...
I 11:20:31 Synchronising Cache...
I 11:20:33 Closing Track...
I 11:20:34 Finalising Disc...
I 11:21:10 Exporting Graph Data...
I 11:21:10 Graph Data File: C:\Documents and Settings\gordon\Application Data\ImgBurn\Graph Data Files\SONY_DVD_RW_DW-Q31A_LYS2_22-APRIL-2010_10-54_MKM-003-00_4x.ibg
I 11:21:10 Export Successfully Completed!
I 11:21:10 Operation Successfully Completed! - Duration: 00:26:45
I 11:21:10 Average Write Rate: 5,266 KB/s (3.8x) - Maximum Write Rate: 5,697 KB/s (4.1x)
I 11:21:10 Cycling Tray before Verify...
W 11:21:17 Waiting for device to become ready...
I 11:21:27 Device Ready!
I 11:21:31 Operation Started!
I 11:21:31 Source Device: [0:0:0] SONY DVD RW DW-Q31A LYS2 (F(ATA)
I 11:21:31 Source Media Type: DVD+R DL (Book Type: DVD+R DL) (Disc ID: MKM-003-00) (Speeds: 4x, 6x, 8x)
I 11:21:31 Image File: -==/\/[BUILD IMAGE]\/\==-
I 11:21:31 Image File Sectors: 3,952,320 (MODE1/2048)
I 11:21:31 Image File Size: 8,094,351,360 bytes
I 11:21:31 Image File Volume Identifier: 2012
I 11:21:31 Image File Application Identifier: IMGBURN V2.5.1.0 - THE ULTIMATE IMAGE BURNER!
I 11:21:31 Image File Implementation Identifier: ImgBurn
I 11:21:31 Image File File System(s): ISO9660, UDF (1.02)
I 11:21:31 Read Speed (Data/Audio): MAX / MAX
I 11:21:31 Verifying Session 1 of 1... (1 Track, LBA: 0 - 3952319)
I 11:21:31 Verifying Track 1 of 1... (MODE1/2048, LBA: 0 - 3952319)
I 11:21:32 Verifying Layer 0... (LBA: 0 - 1976159)
I 11:30:18 Verifying Layer 1... (LBA: 1976160 - 3952319)
W 11:30:31 Failed to Read Sector 1976339 - Reason: L-EC Uncorrectable Error
W 11:30:31 Sector 1976339 maps to File: \VIDEO_TS\VTS_01_4.VOB
W 11:32:07 Retrying (1)...
W 11:32:13 Retry Failed - Reason: L-EC Uncorrectable Error
W 11:33:11 Failed to Read Sector 1976339 - Reason: L-EC Uncorrectable Error
W 11:33:11 Sector 1976339 maps to File: \VIDEO_TS\VTS_01_4.VOB
W 11:33:23 Failed to Read Sector 1976340 - Reason: L-EC Uncorrectable Error
W 11:33:23 Sector 1976340 maps to File: \VIDEO_TS\VTS_01_4.VOB
E 11:44:58 Failed to Read Sector 1976340 - Reason: L-EC Uncorrectable Error
E 11:44:58 Sector 1976340 maps to File: \VIDEO_TS\VTS_01_4.VOB
E 11:44:58 Failed to Verify Sectors!
I 11:44:58 Exporting Graph Data...
I 11:44:58 Graph Data File: C:\Documents and Settings\gordon\Application Data\ImgBurn\Graph Data Files\SONY_DVD_RW_DW-Q31A_LYS2_22-APRIL-2010_10-54_MKM-003-00_4x.ibg
I 11:44:58 Export Successfully Completed!
E 11:44:58 Operation Failed! - Duration: 00:23:26
I 11:44:58 Average Verify Rate: 2,811 KB/s (2.0x) - Maximum Verify Rate: 12,786 KB/s (9.2x)
I 11:47:22 Close Request Acknowledged
I 11:47:22 Closing Down...
I 11:47:22 Shutting down SPTI...
I 11:47:22 ImgBurn closed!
sorry about the half post a little earlier signals, dont know what happened !! finished the post and posted the imgburn log (i hope) just unchecked the remove layer break in dvdfab settings, do you think it could have possibly been that which caused the error? i also have nero 7 installed on pc might try a burn with that, think i'll recopy the movie first though with me unchecking the remove layer break in dvdfab settings. unless there are other suggestions on this problem. its weird anytime i burn using the dvd 5 compression it seems to burn fine. thanks in advance. flash.
Are you doing other tasks while burning?
This almost looks like a bad burn or a defect in the disc
Does the disc play ok?If it ain't broke, don't fix it!
Originally posted by flashgordon View Postsorry about the half post a little earlier signals, dont know what happened !! finished the post and posted the imgburn log (i hope) just unchecked the remove layer break in dvdfab settings, do you think it could have possibly been that which caused the error? i also have nero 7 installed on pc might try a burn with that, think i'll recopy the movie first though with me unchecking the remove layer break in dvdfab settings. unless there are other suggestions on this problem. its weird anytime i burn using the dvd 5 compression it seems to burn fine. thanks in advance. flash.
Did you attempt to alter playback order of any of the titles?
If you're going to try it again, try Clone ModeIf it ain't broke, don't fix it!
Clone mode may not work due to the FAT32 filesystem on the E: drive. The burner needs a firmware update, shows LSY2, latest is LSY7, (dated 2006!) you can find it here: http://drivers.softpedia.com/downloa...irmware+update
Do this carefully and follow Sony's instructions. Disconnect from the internet and do not multitask when flashing new firmware.
Tag teamed LOL.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
Originally posted by signals View PostClone mode may not work due to the FAT32 filesystem on the E: drive.
Ok, time for another cup o' joe.
No "tag back" this time...If it ain't broke, don't fix it!
hi all again, yes it was full disc mode and no the disc doesn't play, tried it in three dvd players, i was disconnected from the internet and i wasn't multi-tasking, havn't tried another disc yet but could try the firmware update that was mentioned if some kind soul could tell me how to install it, i can download it to my desktop but wouldn't know what to do nextthanks in advance. flash.
Flash
Be very careful, if done incorrectly it can turn your drive into a doorstop. Some firmware comes as an executable file that installs it, some requires an additional program to do the job. I suggest you go to the Sony support website and see what they say for instructions. That is a pretty old drive. The link I posted for you will let you download the firmware, not sure about how to flash it on your particular drive but the link may have instructions.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
