Apocalypto
    Apocalypto
    DVDfab has a real problem backing up and converting this Apocalypto Blu Ray disk...
    Constant application crash at every attempt to convert or rip, even when converting the movie after being ripped by other software (which BTW plays great) I've just had to resort to other applications in order to succeed with converting this title..
    have tried v7.0.6.5 , v7.0.6.2 & v7.0.4.0 all with same result using default setting and many other combinations....
    DVDFab 7.0.6.2 (2010/05/27 21:41:23)
    0m 00.57s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 file2mobile 1 filemover 1
    0m 54.49s: got bdmv
    0m 54.80s: got extended bdinfo
    3m 10.38s: begin mobile work ...
    3m 10.38s: create config(5)
    3m 10.38s: convert profile(mp4.h264.aac)
    3m 10.38s: blu-ray playlist(1) angle(0) chapter(1->20)
    3m 10.38s: stream(4113,AVC,1) stream(4352,LPCM,1) stream(4608,PGS,4)
    3m 10.40s: device(mp4) format(mp4)
    3m 10.40s: subpicture preset(1), mode(0)
    3m 10.43s: processing source(00001.m2ts)
    3m 10.43s: try to use gpu acceleration(1) for video decoding
    3m 10.43s: CUDA GPU acceleration for video decoding enabled
    DVDFab 7.0.6.2 (2010/05/27 21:45:03)
    0m 00.59s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 file2mobile 1 filemover 1
    0m 15.19s: got bdmv
    0m 15.21s: got extended bdinfo
    4m 12.37s: begin mobile work ...
    4m 12.37s: create config(5)
    4m 12.37s: convert profile(ipad.mp4)
    4m 12.37s: blu-ray playlist(1) angle(0) chapter(1->20)
    4m 12.37s: stream(4113,AVC,1) stream(4352,LPCM,1) stream(4608,PGS,4)
    4m 12.37s: device(ipad) format(ipod_avc)
    4m 12.37s: subpicture preset(1), mode(0)
    4m 12.39s: processing source(00001.m2ts)
    4m 12.39s: try to use gpu acceleration(1) for video decoding
    4m 12.41s: CUDA GPU acceleration for video decoding enabled
    DVDFab 7.0.6.2 (2010/05/27 21:49:34)
    0m 23.82s: got bdmv
    0m 23.83s: got extended bdinfo
    1m 15.94s: begin mobile work ...
    1m 15.94s: create config(5)
    1m 15.94s: convert profile(mp4.h264.aac)
    1m 15.94s: blu-ray playlist(1) angle(0) chapter(1->20)
    1m 15.94s: stream(4113,AVC,1) stream(4352,LPCM,1) stream(4608,PGS,4)
    1m 15.95s: device(mp4) format(mp4)
    1m 15.95s: subpicture preset(1), mode(0)
    1m 15.97s: processing source(00001.m2ts)
    1m 15.97s: try to use gpu acceleration(1) for video decoding
    1m 15.97s: CUDA GPU acceleration for video decoding enabled
    DVDFab 7.0.6.2 (2010/05/27 21:50:59)
    0m 58.43s: got bdmv
    0m 58.45s: got extended bdinfo
    1m 20.60s: begin mobile work ...
    1m 20.60s: create config(5)
    1m 20.60s: convert profile(mp4.h264.aac)
    1m 20.60s: blu-ray playlist(1) angle(0) chapter(1->20)
    1m 20.60s: stream(4113,AVC,1) stream(4352,LPCM,1) stream(4608,PGS,4)
    1m 20.62s: device(mp4) format(mp4)
    1m 20.62s: subpicture preset(1), mode(0)
    1m 20.63s: processing source(00001.m2ts)
    1m 20.63s: try to use gpu acceleration(1) for video decoding
    1m 20.63s: CUDA GPU acceleration for video decoding enabled
    And this..
    DVDFab 7.0.4.0 (2010/05/28 09:50:21)
    0m 00.62s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 file2mobile 1 filemover 1
    0m 18.36s: got bdmv
    0m 18.36s: got extended bdinfo
    0m 30.98s: begin mobile work ...
    0m 30.98s: create config(5)
    0m 30.98s: convert profile(mp4.h264.aac)
    0m 30.98s: blu-ray playlist(0) angle(0) chapter(1->28)
    0m 30.98s: stream(4113,AVC,1) stream(4352,LPCM,1) stream(4608,PGS,8)
    0m 30.98s: device(mp4) format(mp4)
    0m 30.98s: subpicture preset(2), mode(2)
    0m 31.01s: try to use gpu acceleration(1) for video decoding
    0m 31.01s: CUDA GPU acceleration for video decoding enabled
    Also this.. (but with every Blu Ray title in mobile mkv passthrough)
    09:46:27: Work 1 failed, Error = 500.01 1
    I have a large collection and this is currently the only title with this issue
    Try turning off the CUDA decode. Set it for software decode and encode, then try CUDA encode. You can cancel it after a few minutes if it looks like it is working. Attach all the log files to your next post.
      Well, I did as requested.
      selected software for decoding and encoding tried again; crash immediately..
      selected software+CUDA for encoding only tried again; crashed immediately..
      restarted DVDfab tried again; didn't crash but hung at less than 2% complete and time remaining increasing to 5 hour+ so canceled process.
      installed CoreAVC and restarted.
      selected corecodec for decoding; program crashed repeatedly until removing disk.. then app ran. selected again corecodec for decoding and software+cuda for encoding; DVDfab No longer crashes on opening..
      Inserted Apocalypto disk and tried again; Conversion now hangs at 0.59% fps decreases, time remaining increases.. process was canceled when time to complete reached 5 hours+ and % completed did not change..
      reselected CUDA for decoding and encoding application hangs at same place and subsequent attempts results in immediate application crash...
      Note: with this disk inserted the cpu usage is minimal when application is running and a conversion is in process replace disk with another title all is good.. Original disk plays great and rips with other software..
        I wonder why I can not edit my previous post??
        Anyhow,
        Media center System specs
        i7-920
        6GB memory
        Evga 8800GT (112 CUDA cores)
        8TB raid library
        1TB system drive
        Windows7 x64
        GeForce 197.45
        Apocolypto Blu Ray disk
        XBMC
        PowerDVD10
        CoreCodec Pro
        DVDfab 7.0.4.0
        XXXDVDHD
        MediaShow Espresso
        MakeMKV
        tsMuxerGUI
        mkvmergeGUI
        Fraps
        Handbrake
        Quicktime7 Pro
          Please update your DVDFab to current and try again.
          sigpic
            Like many forums, we have a time window during which posts can be edited. It is generally long enough for second thoughts and correcting typos.
              New version 7066 released this morning.
              http://forum.dvdfab.com/showthread.php?t=5926
                Thank You. And 7066 works great, stable it seems. I need to try Apocalypto again...
                  I've never seen that option in the back end before.. go figure..
                  thx for the heads up
                    OK v7066 works great on many other titles converted today but unfortunately is slow as molasses at converting Apocalypto On Blu Ray and crashes long before completion. Crash report sent..
                    We can add Watchmen (Blu Ray) to the list as it behaves similarly..
                      just got the same error. hangs at .24% completed. using the latest beta version
