HELP!! Threat Detected Warning!!
    I have a fix for you guys i have the full version of avg 9.0 open avg interface and click on resident shield and click on manage exceptions and then click add path click on my computer,then click local disk c. Scroll down to program files to where it says dvdfab 7 and highlight it and click okay button then add path, then click apply and okay i recommend reinstalling it as this point and it should work. It has for me
      DVDFab HELP!! Threat Detected Warning!!
      The workaround suggested by SecretSuperstar worked. Thanks a bunch for now. I hope to find a permanent solution.
        How come it suddenly came up avg has been fine up until now was it because of a virus definitions update. Is this a dvdfab or avg problem if so i hope there is a permanent solution.
          Yep, I getting the same error too. Running AVG Free version CAFF82037E.
          Waiting on fix..
          The Workaround from Justin post, worked..
            This is a false positive created by AVG and you need to contact AVG about it. DVDFab is fine and my virus protection does not report any problems on both of my computers as I have different protection on each of them.
            Again this is not a DVDFab problem
              I had the same thing some time ago with McAfee.
              Best advice I got from someone here was that IF you are only copying DVD to DVD as I do, copy your DVDs while off line, and also disable automatic updates, just check for them here on the Forums.
              I believe it is different for Blu-rays.
                being a new computer user not really up with everything but does this problem with avg normally right itself after they check it out as ive tried to use fab offline and it still comes up with the same error message.
                  Thank you SecretSuperstar! I simply "ignore"d the warning then did just as you suggested and it works just fine now. Thanks for the help!
                    Yes AVG will release an update that fixes this if enough people report this false positive to them
                      Thank you very much for your quick reply it is really appreciated and i will add a report to them.
                        Same problem here!!
                        Are there no mods on line now????
                        SD
                          read post #28 created by SecretSuperstar to fix or click link below
                            This solved the problem. Well done
                              Hi guys do a avg update now and i think you will find this fixes the problem it did for me. I removed the manage exceptions thing and dvdfab works but you might have to reinstall dvdfab and then it works fine again
                                AVG Threat
                                Need to update to AVG 9.0. No problem after that.
