Updates
    Updates
    hi all
    I'm fairly new to dvd fab, I have purchased it for 2 years, and I was just wondering if anyone could answer this question. Sometimes when I put a DVD in my drive it comes up with a screen saying update available which I always do, is this normal and what does it do because it seems the same afterwards. I know this may be a silly question but as I said I'm fairly new to this. Thank you all for your time and advice.
    :) never look down on anyone unless you're looking down at them to help them up:)
    tdk,
    If these notifications annoying for you, you can disable "check for updates" in "General" section of Common Settings.
    sigpic
      hi ipopov50
      They are not annoying me, but I just wondered what they do, because there doesn't seem any change afterwards. And should I let it update as I'm doing. Thank you for your quick reply.
        There is no change since they are just notifications. They do not download or install anything.
          Originally posted by tdk View Post
          ...it comes up with a screen saying update available which I always do...because it seems the same afterwards.
          I know this may be a dumb question, but you are downloading and installing it when this happens right? DVDFab is not like Anti-Virus updates where it installs itself.
            Not dumb at all from my perspective.
            I think he's under the impression that Fab auto updates rather than simply a notification that an update is available.
              Updates
              hi thanks for all your help. Yes I thought it was automatically updating dvdfab for me so as soon as it comes on my screen I click it to update. The version I have is 7.0.93 is this the newest one available, if not how do I do a update. This may sound silly to some people but as I said I'm fairly new to this. Once again thank you for your help and time
                It is up to you of course, but what I do now, works best for me, is I have turned off the check for updates and I check these Forums at least once a day, when the are new updates here, either official or beta versions, I instal them from here.
                  That's what I do also.
                    same thing I do as well. I even have the check for updates off so I not get the annoying message
                      Totally agree with Davis procedure, It is exactly what I use.
                      I will make another point though.
                      Keep all the old installers. Space is cheap and you never know when you will want to revert for some reason or other.
                      I have an install libraqry since V3 and, on may ocassions, I have been very glad that I did this right from the start.
                        Updates
                        hi all
                        Thank you for all your advice, much appreciated. My last question is what is a beta version and should I install it. And how do I save my old version and install a new one without deleting my old one. I hope this makes sense. Once again thank you for your advice and time.
                          hi all
                          Your question is perfectly sensible, however it is one thing I have never been too sure about, so will leave it to one of the experts to answer fully.
                            You just install over the top and it retains your setting & registration info.
                            You cannot have multiple versions of the same major release installed but you may have multiple installations of different major versions.
                            eg. You can have any release of Version 3, 4, 5, 6 & 7 all installed but you cannot have multiple versions of 7 installed.
                            This is why I said to keep the installers so that you can revert at any time.
                              hi all
                              Not sure if this will help or not, just trying to help, maybe you do this already.
                              What I do is when each version, beta or official, is released I download it to my desktop, then instal it and it automatically instals over my DVD Fab, but I then keep the last few installers on my desktop just in case of problems.
                              Every so often I delete the older installers from my desktop but keep DVD Fab installed, in my case 6 and 7.
