Can DVD Shrink be used to compress the file after Decrypter has done its job? And, can Power DVD be used to burn the file to DVD-R? Will this combination work? Thanks for your help.
DVD Fab HD Decrypter
Originally posted by TLN View PostCan DVD Shrink be used to compress the file after Decrypter has done its job? And, can Power DVD be used to burn the file to DVD-R? Will this combination work? Thanks for your help.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
You're welcome. Try the 30-day free trial of the full DVDFab, it's all in one UI.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
