Billing problem USA State/Province
    I am having a problem paying for renewal. The box marked state/province has "None" in it and won't allow me to put in my state. I can't go forward without this. Can anyone help? Thanks.
    We are users here just like you but I'm sure someone can figure something out but in the mean time did you submit a contact form about this problem. link for that below
      Will keep you updated on billing problem
      Hi AGJ, I posted a contact and will keep you updated on what they suggest.
      Thanks so much.
        It was a browser problem
        For some reason, Firefox would not allow me to enter my State. I went to IE and managed to do it that way.
          Try using the TAB key to navigate into the State box, then enter the uppercase first letter of the state, it should pop up.
