[HELP] Activation
    Other [HELP] Activation
    I bought and activated DVDFAB 8 properly, but when I do a rip, conversion, etc, It says in the log " You are going to try "DVD to Mobile" option...
    But It rips fine...
    Please help...
    That message probably means the product is not registered properly. Please verify this by clicking on the "?" in the upper right corner of the DVDFab window and select About from the list. It will show whether each component is "Enabled" and, if registered, it will show your name as the registered owner and an expiration date for each product (or say "Never Expire" if you bought lifetime). It is very important to run the DVDFab installer As Administrator. You will get the message for products you did not buy if you try to use them.
