I have v8.0.0.5 and it is fine so far but v7 is gone Kaspersky killed it hope it don't mess with v8 still have over 100 days of pertection with Kaspersky
Avira Reporting Beta 8015 contains Virus
DVDFab 8.0.1.6
After installing the Beta DVDFab 8.0.1.6 and reboot your PC Kaspersky 2011 blocks the program and its shortcut crashes, gives the following message asking if you really want to "uninstall the program." Already uninstalled DVDFab, disabled the KIS, I put the program as reliable, but still after restarting the pc it crashes. I can only use it to install and will not shut down your PC! Anyone else having trouble?
Originally posted by Smallwil View PostAfter installing the Beta DVDFab 8.0.1.6 and reboot your PC Kaspersky 2011 blocks the program and its shortcut crashes, gives the following message asking if you really want to "uninstall the program." Already uninstalled DVDFab, disabled the KIS, I put the program as reliable, but still after restarting the pc it crashes. I can only use it to install and will not shut down your PC! Anyone else having trouble?Programmer in Python, Java, JavaScript, Swift, PHP, SQL, C#, C++, Go, R
How To Resolve Kaspersky & DVDFab Prolem
The Problem Lies In The Script Of Kaspersky 2011
You Need To Download Kaspersky 2010
Google It & Search For Kaspersky Antivirus Or Internet Security 2010
Un-install DvdFab
Un-install Kaspersky 2011
Clean Out Any Folders For Kaspersky Or DVDFab From Your Hard Drive Usually Drive c:\
Run System Cleaner Like CCleaner
Re Boot Pc
Re-install DVDFAB Apply Your Registration1Details
Install Kaspersky 2010
Use Same Key To Activate
Run Update For Kaspersky 2010
Restart Pc
Thats It
Working DVDFab & Kaaspersky
When & If Kaspersky Fix The Script Then Return To Version 2011
Works 100%
Originally posted by MovieBuff View PostHow do you know it's a false positive? I also use KIS and until they tell me differently im just going to have to stop using the program.
I'm very disappointed about it.
I'm not sure how you justify assigning responsibility to Fab.
Did you read the post above yours by TECHNOMAN?
All av apps have problems from time to time, some more than others.
As for KIS, while it does an excellent job, it tends to be a bit over-the-top.
Heck, KIS has had reports of problems with win7, Windows Defender in particular. Would you stop using Windows based on this?
There has been no deluge of "reported viruses" with Fab...just the random event such as you reported.
Sorry, but this is a non-issue for FabIf it ain't broke, don't fix it!
Guest
So why are you complaining about a false positive that was 14 days ago on a now out of date version?
thread closed
