DVDFab and USB device
    I just installed DVDFab 8, but every time I run it, it disconnects my USB 3G modem.
    I'm using Windows 7 Ultimate x64.
    It also happened when I used DVDFab 7.
    The software works but during the time I'm running it I can't access Internet because my modem is disconnected.
    Is there anything I can do to solve it?
    Is this the same problem you posted about April 18th ?
    Has this been happening for 5 months without a fix?
      Yes, it's the exact same problem.
        Does this modem appear in My Computer as a disc drive?
          I think it does.
          It appears in "My Computer" in "Devices with Removable Storage" together with my DVD drive and my virtual drive. It appears as if it was a pen drive.
