Am I missing something or is there still a platinum version available that has all the modules available?
DVDFab: DVD Platinum?
Hi, dwoods and welcome to the new DVDFab Forum.
Beginning with Version 6, you only need to buy the options you want (you can still buy them all, and you can buy the license term you want as well). If you have a license for a previous version of Gold or Platinum, you can get a key for version 6 free. It is all explained on from the Tutorial.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
