I'm confused. How do you use customize in the new Fab version? When I click on customize I get a message to that takes me the Fab site. Then what? What's going on? Can I get an explanation on how to use customize ? This probably should be in the DVD thread, sorry
License Issues / How do u use customize now??
Guest
Is it a registered version or the free version?
Post all the details.
Customize is working as it should for me.
downloaded new fab to 3 computers
I downloaded the newest version of Fab from the link at the forum to my 3 computers and reentered my code and I still get the same message when I click on "customize" that "Customize is availabel in DVD Fab Copy" and it gives me a link to click on. What's goin on?
As my friend Gruñón suspected, it sounds like you're still stuck in the freeware mode...ie., your regkey was not activated.
Please read through and follow the instructions here:
DVDFab Registration Key Problems?If it ain't broke, don't fix it!
Please use "?"->About (upper right corner) to check your registration status.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
Originally posted by Johnpayd View Postafter I paste my code in
Originally posted by Johnpayd View Posttried that.still doesn't work
Originally posted by Johnpayd View PostOnce again I did and nothing worksLast edited by craigb; 11-01-2010, 06:36 PM.
I think I would try what craigb suggests, although it should not be necessary. Use the uninstaller that comes with DVDFab, then the reg cleaner to catch any leftovers. Then download a new key and a new installer to your desktop. Run the installer As Administrator, then close DVDFab and see if the key file shows up with the DVDFab logo. If it does, you should be able to double click it to register and start DVDFab. If it does not, use the file association method of opening the key file with the dvdfab.exe file. You might also disconnect from the internet and disable your antivirus/security software during the installation/registration process. Don't forget to turn it back on afterwords.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
fab 8 is registered but can't access "Customize"
I have tried ALL the suggestions by the administators to activate Fab 8, My registration is up to date and shows up as updated yet I can't acesss all the features of Fab 8. This is happening on all 3 of my computers. I have been a paying member for a few years now and I have NEVER HAD THE PROBLEMS I AM HAVING NOW. I have downloaded my number to my computer, I have copy and pasted it. Nothing works. PLEASE HELP
I don't know if this is relevant, but I hope you weren't online with more than 1pc running Fab at the same time. This is a no-no.
If yes, it's possible your license was "blacklisted" because it was seen as "pirated".
If you think this happened, please pm your license info to signals (admin) and Fengtao
I just looked at your last thread and I don't see this...if you click About and display your license info...what the status?If it ain't broke, don't fix it!
