Which product?
    Which product?
    I have some already decrypted DVD movies that I want to put onto a flash drive so I can watch them on my notebook computer. I've learned that I have to convert them to an AVI file. But that's about all I've learned. Please excuse my ignorance, but this is one subject I really know extremely little about. My question is, do I need the DVD Ripper or the Video Converter?
    If the movies are still in DVD format (in a VIDEO_TS folder with IFO, BUP and VOB files) then you need DVD Ripper.
      No need to convert the movie to AVI for a flash drive.
      Format the flash drive to NTFS to get away from the Fat 32 file size limitation and you are good to go.
      Instructions to format flash drive to NTFS.............
      FAQ - How do I format a USB Flash Drive to NTFS file system? To enable NTFS on your USB Flash Drive drive
