Led Zeppelin Celebration Day will not compress to BD25
    I got some odd behavior, ripped to full disc on the HDD and I couldn't compress the folder to full BD-25 no way no how, 401 error. Tried the same disc and it completed fine from the disc to BD-25?
      Hi 90312,
      Yes... this is strange, But please keep working on a fix for this Great Program, we shouldn't be forced to use 3rd party software (like Rex did) to compress the BD50 to a BD25, Like I said, My Led Zeppelin Celebration day still stalls at 98.14%, but another disk I had The Imaginarium of Doctor Parnassus I was able to compress from a DVDFab Full disk copy on a BD50-RE DL to a BD25, but it wouldn't compress from the original disk or from the BD50 saved on the hard drive (logs where posted for that in another thread)
      Thank You Again... and I hope we can get this resolved.
        Hi Holoperson
        We moderators are members just like you but with moderator privileges.
        We have no input as to what gets fixed or know what is getting fixed.
        We know when you know?
        CBR929
          Hi Holoperson
          CBR929
          Thank You CBR929, You (the moderators) all do fantastic work here...
          I just hope Someone from DVDFab can fix this issue,
          as it is affecting numerous people, but in strange ways, such as Rex who has saved BD50 on his hard drive, and now can not compress them to BD25 where as DVDFab in the past did compress these same BD50 images off of his hard drive to BD25 without problem. and others who have the compression issue with disks that gave DVDFab no problems before... such as Star Trek IV, MIB 3, The Avengers...
          Thank You again
            Hi Holoperson
            Have you ever tried release 8085 with this problematic disc?
            If not give it a try
            CBR929
              Hi Holoperson
              CBR929
              Yes, CBR929, I did try v8.0.8.5 and it stalls at 98.14% as well,
                Well I tried both v8.2.2.7QT and v9.0.2.6 and still the same issue, when it is compressing / Encoding they both stall at 98.14% and just sit there, until I cancel the copy...
                This is a Feature We Paid For and it should work!!!
                  I tested this disc just now with V8227. Looks disable CUDA then works well.
                  I did BD 50 to 25, MainMovie.
                    Also please do not enable the "Lighting-Recoding"
                      Hi Potti, OK... v8.2.2.7 All GPU Codecs Disabled = Software only
                      Lightning-Recoding Not Enabled
                      Source = From iso BD50 full disc copy by DVDFab on Hard Drive
                      Target = Movie Only... BD25 iso to hard drive
                      Guess What... It Stalls at Compression Encoding at 98.20%
                      But I want the Full Disc with the Menus... Which DVDFab should be able to do...
                      Here are the logs... from the Movie only attempt...
                        Hi Holoperson,
                        How about copy from the original disc?
                          Originally posted by terry5 View Post
                          Hi Holoperson,
                          Hi terry5...
                          With v9.0.2.6
                          OK Full Disc copy, BD50 > BD25
                          Disable all GPU codecs Checked
                          enable Lightning-Recoding Unchecked
                          Source Original disc
                          Target BD25 Blank
                          still stalls at 98.14% of encoding / compressing...
                          it's not hung as the progam let's me cancel the copy and then click Finish and exit the program...
                          Here are the logs from this attempt
                            I know it's a bit late to ask this as it has gone on for ages but does this disk have a LPCM audio track?
                              Beat me to my question.
                              CBR929
                                The Disc has PCM Stereo and 5.1 DTS-HDMA options from the setup menu on the disc
                                Removed the HD audio...
                                v9.0.2.6
                                This one is from the DVDFab made BD50 iso on the hard drive
                                Full Copy BD50 > BD25
                                Disable All GPU codecs - Checked
                                Enable Lightning-Recoding - Not Checked
                                Remove HD Audio - Checked
                                it still tries to encode / compress the disc
                                and it stall at 98.00%
                                and here are these logs...
