Led Zeppelin Celebration Day will not compress to BD25
    Also of Note here is that the 25fps EU ONLY release specs
    Video
    Codec: MPEG-4 AVC
    Resolution: 1080/50i
    Aspect ratio: 1.78:1
    Original aspect ratio: 1.78:1
    Audio
    English: DTS-HD Master Audio 5.1 (48kHz, 16-bit)
    English: LPCM 2.0 (48kHz, 16-bit)
    while the 24fps USA release specs
    Video
    Codec: MPEG-4 AVC
    Resolution: 1080i
    Audio
    English: DTS-HD Master Audio 5.1 (48kHz, 24-bit)
    English: LPCM 5.1 (48kHz, 24-bit)
    English: LPCM 2.0 (48kHz, 24-bit)
    So we have 1080/50i and 16 bit audio on the EU ONLY release
    and 1080i and 24bit audio on the USA release
    I hope The DVDFab team can get the program to copy these different releases of what should be the same blu-ray.
      Just tried with version v9.0.2.8
      Still same issue stalling at 98.14%
        will work on 50gb blu-ray disc
        I had the same problem with a mariah carey & rihanna blu ray disc's. even in my dvdfab player when I tried to compress it to a full disc 25gb folder so I could get the menu for the song list it would not work. if I played the 50gb folder it would play. I did a main movie 25gb back up it did work but will not have a song list so you can go to play a you would like. so I found these 5ogb blu-rays at mirco center $70.00 for 15 which comes to about $4.67 each & the work great
          We have reproduced this issue with Led Zeppelin Celebration Day and we'll fix it asap.
          Thanks for your support!
            Thank You, DVDFab is a Great Program, That is even better because of The Great People that support it!!!
