Burned movie missing parts
    I have DVD Fab on two computers. A purchased version on one and trial version on another.
    The computer that had the purchased version has recently been burning with errors - not burning the whole movie - missing sections.
    I thought the comp had burner problems so I downloaded dvdfab to my other computer and have found it does the same thing.
    There were no error codes and nothing else was open or being used when I burned the movie on the trial version.
    Why is it burning with missing chapters?
    I copy the movie to the hard drive and then burn it to the dvd using write data as per the info on the dvdfab website faq's.
    anyone know what I"m going wrong? I would really appreciate any help you can give me.
    Hi eworks
    Please use attachment button and attach your most recent, Internal and Burn log(s) and post right here.
    CBR929
      What copy mode were you using and what movies have done this? Twilight: Eclipse will do this in certain cases, but not if you used Full Disc copy mode.
        I used DVD Copy - Main Movie to copy it to the hard drive and Write Data to place it on the dvd.
        Both logs wont fit as the forum tells me they're too long in characters - dvdfab internal & dvdfab burn vso. So I'll attach them instead.
          Movie in question is Sorcerer's Apprentice but I've had this happen on the old computer with Karate Kid, Iron Man 2.
            Hi eworks
            Please download and install ImgBurn it is (free) and you will find it here along with a tutorial on how to set it up with Fab http://forum.dvdfab.com/showthread.php?t=33 do not forget to set up the AWS in ImgBurn and set it to 1/2 the rated speed of your disc's.
            Also the disc's you are using are considered garbage consider picking up some Taiyo Yuden or Verbatim with the (AZO dye) on the label.
            May I also ask why you are burning your movies on DL disc's....those file sizes have no problem fitting on a SL disc. If you are using main movie be sure to check DVD9 on the bottom of the main screen if you want to use the DL disc with no compression.
            Give these a try and post back
            CBR929
