Having problems with sound
    music plays but voices are muffled and and distant through out the movies ? is it a setting i have wrong ? thanks for the help !
    This is usually caused by not having the correct codecs on your PC. Download and install FFDShow codec.
      DVDFab DVD to DVD does not modify the audio streams in any way. If they sound different it is player-related, perhaps the codec as GregiBoy noted.
        Is this just on one movie, or more than one?
        Just I had this on one movie some time ago, a long movie that had to be shrunk quite a bit, I made another copy and it was okay, I assumed and still do it was a faulty blank disc.
