Successes and Problem DVD's using DVDFab 6.1.2.5
    EDIT: !!!!! Please post any issues regarding NEW release DVD's that you think 6.1.2.5 is not decrypting properly !!!!!
    OK folks I'm here to report that the PROBLEM BEAST "Transformers 2 - Revenge of the Fallen" is NO LONGER an issue for creating a "Full Disc" backup with DVDFab 6.1.2.5
    IMPORTANT:
    Be sure to go back and review your PathPlayer setting (the Green Check, top right). Make sure it is set back to either "Always Enabled" or "Enable PathPlayer when necessary".
    You want to select "Always Enabled" if you use any of the features in box that says "Navigation". I normally correct my own navigation with another tool so I use "Enable PathPlayer when necessary", either should work for this disc.
    Then try "Full Disc" mode. I was very impressed with the latest results, here is a view of the files after it completed:
    Volume in drive M is AX_MOVIE3
    Volume Serial Number is 3B51-D440
    Directory of M:\FullDisc\TRANSFORMERS2_D1_VANILLA\VIDEO_TS
    10/27/2009 06:04 PM <DIR> .
    10/27/2009 06:04 PM <DIR> ..
    10/27/2009 06:02 PM 30,720 VIDEO_TS.BUP
    10/27/2009 06:02 PM 30,720 VIDEO_TS.IFO
    10/27/2009 06:02 PM 913,408 VIDEO_TS.VOB
    10/27/2009 06:02 PM 18,432 VTS_01_0.BUP
    10/27/2009 06:02 PM 18,432 VTS_01_0.IFO
    10/27/2009 06:02 PM 524,288 VTS_01_0.VOB
    10/27/2009 06:02 PM 342,016 VTS_01_1.VOB
    10/27/2009 06:02 PM 14,336 VTS_02_0.BUP
    10/27/2009 06:02 PM 14,336 VTS_02_0.IFO
    10/27/2009 06:02 PM 14,336 VTS_02_1.VOB
    10/27/2009 06:02 PM 18,432 VTS_03_0.BUP
    10/27/2009 06:02 PM 18,432 VTS_03_0.IFO
    10/27/2009 06:02 PM 14,336 VTS_03_1.VOB
    10/27/2009 06:02 PM 20,480 VTS_04_0.BUP
    10/27/2009 06:02 PM 20,480 VTS_04_0.IFO
    10/27/2009 06:02 PM 14,336 VTS_04_1.VOB
    10/27/2009 06:02 PM 20,480 VTS_05_0.BUP
    10/27/2009 06:02 PM 20,480 VTS_05_0.IFO
    10/27/2009 06:02 PM 14,336 VTS_05_1.VOB
    10/27/2009 06:02 PM 22,528 VTS_06_0.BUP
    10/27/2009 06:02 PM 22,528 VTS_06_0.IFO
    10/27/2009 06:02 PM 14,336 VTS_06_1.VOB
    10/27/2009 06:02 PM 20,480 VTS_07_0.BUP
    10/27/2009 06:02 PM 20,480 VTS_07_0.IFO
    10/27/2009 06:02 PM 14,336 VTS_07_1.VOB
    10/27/2009 06:02 PM 114,688 VTS_08_0.BUP
    10/27/2009 06:02 PM 114,688 VTS_08_0.IFO
    10/27/2009 06:02 PM 94,263,296 VTS_08_0.VOB
    10/27/2009 06:02 PM 1,073,739,776 VTS_08_1.VOB
    10/27/2009 06:02 PM 1,073,739,776 VTS_08_2.VOB
    10/27/2009 06:02 PM 1,073,739,776 VTS_08_3.VOB
    10/27/2009 06:02 PM 1,073,739,776 VTS_08_4.VOB
    10/27/2009 06:02 PM 1,073,739,776 VTS_08_5.VOB
    10/27/2009 06:02 PM 1,073,739,776 VTS_08_6.VOB
    10/27/2009 06:02 PM 1,073,739,776 VTS_08_7.VOB
    10/27/2009 06:02 PM 402,237,440 VTS_08_8.VOB
    10/27/2009 06:02 PM 20,480 VTS_09_0.BUP
    10/27/2009 06:02 PM 20,480 VTS_09_0.IFO
    10/27/2009 06:02 PM 14,336 VTS_09_1.VOB
    10/27/2009 06:02 PM 20,480 VTS_10_0.BUP
    10/27/2009 06:02 PM 20,480 VTS_10_0.IFO
    10/27/2009 06:02 PM 14,336 VTS_10_1.VOB
    10/27/2009 06:02 PM 20,480 VTS_11_0.BUP
    10/27/2009 06:02 PM 20,480 VTS_11_0.IFO
    10/27/2009 06:02 PM 14,336 VTS_11_1.VOB
    10/27/2009 06:02 PM 22,528 VTS_12_0.BUP
    10/27/2009 06:02 PM 22,528 VTS_12_0.IFO
    10/27/2009 06:02 PM 14,336 VTS_12_1.VOB
    10/27/2009 06:02 PM 22,528 VTS_13_0.BUP
    10/27/2009 06:02 PM 22,528 VTS_13_0.IFO
    10/27/2009 06:02 PM 14,336 VTS_13_1.VOB
    10/27/2009 06:02 PM 18,432 VTS_14_0.BUP
    10/27/2009 06:02 PM 18,432 VTS_14_0.IFO
    10/27/2009 06:02 PM 20,162,560 VTS_14_0.VOB
    10/27/2009 06:02 PM 14,336 VTS_14_1.VOB
    56 File(s) 8,035,604,480 bytes
    2 Dir(s) 3,107,201,024 bytes free
    I did however do a little further cleanup with PgcEdit (PGC Editor/Blanking only, non-decrypton tool) as I'm a stickler on my final backups. I have a portable player that is sometimes a real pain if there is too much program chain jumping. Plus I like to change the program "First Play" order so that the MPAA plays first (if available), then it jumps directly to the movie and then the Menus when the movie is over. Plus PgcEdit has a very nice feature to remove ALL uncalled PGC's.
    PgcEdit is NOT needed for for you to get a Full Disc backup.
    REMEMBER: Turn PathPlayer back ON !!!
    Cheers,
    FYI: Tinker Bell next
    AX
    The default Log File location: C:\Documents and Settings\"User Acct"\My Documents\DVDFab\Log
    i must be retarded... i upgraded to 6.1.2.5
    the top of my program now says 6.1.2.5 non-css. when i stick in the dvd, it says that this version of dvdfab is unable to backup the program. i am also looking for th area where pathplayer USED to be... it is no longer there?!
    i could use a little help or a sanity check... thanx
      disc 2
      has anyone had a problem with disc 2? i cant get it to open
        Where did you download it from? It should read "DVDFab 6.1.2.5 (27/10/2009)"
        Download from the links in this forum.
          i have updated and and still a no go
            Good NEWs on "Tinker Bell and the Lost Treasure (R1)", I was able to successfully do a "Full Disc" on it as well. I'm currently checking the files with PgcEdit.
            IMPORTANT:
            Be sure to go back and review your PathPlayer setting (the Green Check, top right). Make sure it is set back to "Enable PathPlayer when necessary".
            Here what the files look like an I have on doubt I will get a working back up of Tinker Bell. I love these "Fast Play" Disney DVD's and I have room to work with in getting the whole thing on a SL (4.7g) disc.
            .Volume.in.drive.M.is.AX_MOVIE3
            .Volume.Serial.Number.is.3B51-D440
            .Directory.of.M:\TINKER_BELL_LOST_TREASURE\VIDEO_T S
            10/27/2009..08:07.PM....<DIR>...........
            10/27/2009..08:07.PM....<DIR>............
            10/27/2009..08:07.PM.................0.Tinker_Bell_LT_Di r.txt
            10/27/2009..07:42.PM............38,912.VIDEO_TS.BUP
            10/27/2009..07:42.PM............38,912.VIDEO_TS.IFO
            10/27/2009..07:42.PM...........284,672.VIDEO_TS.VOB
            10/27/2009..07:42.PM............20,480.VTS_01_0.BUP
            10/27/2009..07:42.PM............20,480.VTS_01_0.IFO
            10/27/2009..07:42.PM............10,240.VTS_01_0.VOB
            10/27/2009..07:42.PM...........878,592.VTS_01_1.VOB
            10/27/2009..07:42.PM............18,432.VTS_02_0.BUP
            10/27/2009..07:42.PM............18,432.VTS_02_0.IFO
            10/27/2009..07:42.PM............10,240.VTS_02_0.VOB
            10/27/2009..07:42.PM.......124,516,352.VTS_02_1.VOB
            10/27/2009..07:42.PM............18,432.VTS_03_0.BUP
            10/27/2009..07:42.PM............18,432.VTS_03_0.IFO
            10/27/2009..07:42.PM............10,240.VTS_03_0.VOB
            10/27/2009..07:42.PM........66,670,592.VTS_03_1.VOB
            10/27/2009..07:42.PM............28,672.VTS_04_0.BUP
            10/27/2009..07:42.PM............28,672.VTS_04_0.IFO
            10/27/2009..07:42.PM............10,240.VTS_04_0.VOB
            10/27/2009..07:42.PM.......325,040,128.VTS_04_1.VOB
            10/27/2009..07:42.PM............20,480.VTS_05_0.BUP
            10/27/2009..07:42.PM............20,480.VTS_05_0.IFO
            10/27/2009..07:42.PM............10,240.VTS_05_0.VOB
            10/27/2009..07:42.PM........40,638,464.VTS_05_1.VOB
            10/27/2009..07:42.PM............18,432.VTS_06_0.BUP
            10/27/2009..07:42.PM............18,432.VTS_06_0.IFO
            10/27/2009..07:42.PM............10,240.VTS_06_0.VOB
            10/27/2009..07:42.PM.......114,888,704.VTS_06_1.VOB
            10/27/2009..07:42.PM............32,768.VTS_07_0.BUP
            10/27/2009..07:42.PM............32,768.VTS_07_0.IFO
            10/27/2009..07:42.PM............14,336.VTS_07_1.VOB
            10/27/2009..07:42.PM............32,768.VTS_08_0.BUP
            10/27/2009..07:42.PM............32,768.VTS_08_0.IFO
            10/27/2009..07:42.PM............14,336.VTS_08_1.VOB
            10/27/2009..07:42.PM............32,768.VTS_09_0.BUP
            10/27/2009..07:42.PM............32,768.VTS_09_0.IFO
            10/27/2009..07:42.PM............14,336.VTS_09_1.VOB
            10/27/2009..07:42.PM............32,768.VTS_10_0.BUP
            10/27/2009..07:42.PM............32,768.VTS_10_0.IFO
            10/27/2009..07:42.PM............14,336.VTS_10_1.VOB
            10/27/2009..07:42.PM............32,768.VTS_11_0.BUP
            10/27/2009..07:42.PM............32,768.VTS_11_0.IFO
            10/27/2009..07:42.PM............14,336.VTS_11_1.VOB
            10/27/2009..07:42.PM............32,768.VTS_12_0.BUP
            10/27/2009..07:42.PM............32,768.VTS_12_0.IFO
            10/27/2009..07:42.PM............14,336.VTS_12_1.VOB
            10/27/2009..07:42.PM............32,768.VTS_13_0.BUP
            10/27/2009..07:42.PM............32,768.VTS_13_0.IFO
            10/27/2009..07:42.PM............14,336.VTS_13_1.VOB
            10/27/2009..07:42.PM............92,160.VTS_14_0.BUP
            10/27/2009..07:42.PM............92,160.VTS_14_0.IFO
            10/27/2009..07:42.PM.......400,650,240.VTS_14_0.VOB
            10/27/2009..07:42.PM.....1,073,739,776.VTS_14_1.VOB
            10/27/2009..07:42.PM.....1,073,739,776.VTS_14_2.VOB
            10/27/2009..07:42.PM.....1,073,739,776.VTS_14_3.VOB
            10/27/2009..07:42.PM.....1,073,057,792.VTS_14_4.VOB
            10/27/2009..07:42.PM............32,768.VTS_15_0.BUP
            10/27/2009..07:42.PM............32,768.VTS_15_0.IFO
            10/27/2009..07:42.PM............14,336.VTS_15_1.VOB
            10/27/2009..07:42.PM............32,768.VTS_16_0.BUP
            10/27/2009..07:42.PM............32,768.VTS_16_0.IFO
            10/27/2009..07:42.PM............14,336.VTS_16_1.VOB
            10/27/2009..07:42.PM............32,768.VTS_17_0.BUP
            10/27/2009..07:42.PM............32,768.VTS_17_0.IFO
            10/27/2009..07:42.PM............14,336.VTS_17_1.VOB
            10/27/2009..07:42.PM............20,480.VTS_18_0.BUP
            10/27/2009..07:42.PM............20,480.VTS_18_0.IFO
            10/27/2009..07:43.PM............10,240.VTS_18_0.VOB
            10/27/2009..07:43.PM.......197,466,112.VTS_18_1.VOB
            10/27/2009..07:42.PM............32,768.VTS_19_0.BUP
            10/27/2009..07:42.PM............32,768.VTS_19_0.IFO
            10/27/2009..07:43.PM............10,240.VTS_19_0.VOB
            10/27/2009..07:43.PM.......525,899,776.VTS_19_1.VOB
            10/27/2009..07:42.PM............20,480.VTS_20_0.BUP
            10/27/2009..07:42.PM............20,480.VTS_20_0.IFO
            10/27/2009..07:43.PM............10,240.VTS_20_0.VOB
            10/27/2009..07:43.PM.......271,097,856.VTS_20_1.VOB
            10/27/2009..07:42.PM............24,576.VTS_21_0.BUP
            10/27/2009..07:42.PM............24,576.VTS_21_0.IFO
            10/27/2009..07:43.PM............10,240.VTS_21_0.VOB
            10/27/2009..07:43.PM.......299,884,544.VTS_21_1.VOB
            10/27/2009..07:42.PM............18,432.VTS_22_0.BUP
            10/27/2009..07:42.PM............18,432.VTS_22_0.IFO
            10/27/2009..07:43.PM.........1,497,088.VTS_22_0.VOB
            10/27/2009..07:43.PM.........6,957,056.VTS_22_1.VOB
            10/27/2009..07:42.PM............18,432.VTS_23_0.BUP
            10/27/2009..07:42.PM............18,432.VTS_23_0.IFO
            10/27/2009..07:43.PM............10,240.VTS_23_0.VOB
            10/27/2009..07:43.PM........20,736,000.VTS_23_1.VOB
            10/27/2009..07:42.PM............18,432.VTS_24_0.BUP
            10/27/2009..07:42.PM............18,432.VTS_24_0.IFO
            10/27/2009..07:43.PM............10,240.VTS_24_0.VOB
            10/27/2009..07:43.PM........10,256,384.VTS_24_1.VOB
            10/27/2009..07:42.PM............20,480.VTS_25_0.BUP
            10/27/2009..07:42.PM............20,480.VTS_25_0.IFO
            10/27/2009..07:43.PM...........706,560.VTS_25_0.VOB
            10/27/2009..07:43.PM.........1,810,432.VTS_25_1.VOB
            ..............97.File(s)..6,705,938,432.bytes
            ...............2.Dir(s)..37,744,013,312.bytes.free
            !!!! Make sure PathPlayer is enabled !!!!
            Cheers
            AX
              Can't help with disc 2 .... but did Disc 1 work ? ?
              Have you used DVDFab before, is it the purchased or free version ?
              Need more details, don't be so vague .... help me to help you !
              AX
                am i the only one having this problem???
                  Don't know but you are the only one not supplying any details.
                    ok sorry. i am a long time user. disc one i had no problems once updated. side note, thanks fendego. but once i tried disc two, i just keeps tring to open, never stops
                      my issue is different. I downloaded this version, installed it, rebooted, and when it tried to read TF2 disk, it gave me an error that says "to open the DVD disk buy or renew "dvd to dvd" wait for new version of dvdfab hd decrypter"
                      Is DVDFab no longer free?
                        i have also had no problems with tinkerbell and orphan this week. went thru with no problems
                          Well it would be a good idea to help the GREAT developers of this tool by purchasing a license. They do spend quite a lot of hours developing DVDFab to work with these latest protections.
                          Let's say you need to have your car repaired, should it be free ?
                          I even donate to FREEWARE tools if I use them frequently, its only fair if you want to continue using them and so that the developers can continue making enhancements.
                          Do you agree ?
                          Regards,
                          AX
                            and tha version i have is NOT the free one
                              disk two has a lot of extra including a download to instal an optmis prime hologram thru your webcam. would that put the whammy on it?
