Successes and Problem DVD's using DVDFab 6.1.2.5
    Originally posted by GregiBoy View Post
    Where did you download it from? It should read "DVDFab 6.1.2.5 (27/10/2009)"
    Download from the links in this forum.
    Greg thank you for the reply. I am a long time user of dvdfab and have been since version 3 or 4? anyhow, i did download from here and activate w/ my code. the top says exactly what you put, but in addition it also says non-css version.
    let me know what other information is required to help me figure this out.
    thanks fellas!
      Download from here and reinstall and let us know how you get on.
        Just thought I'd report the fact that the latest version - 6.1.2.5 - worked perfectly with both Transformers 2 and the other one I was having problems with, namely, Ken Burns - The National Parks. And just as a side note, I had PathPlayer set to Enable Always rather than Enable When Needed. Thanks to the developer and his quick and brilliant cracking abilities.
        "No Copy Protection Scheme Can Outsmart The Cracking Perfection Team"
        sleeper1428
          ok nm.... seems they actually changed the dl version from non-css to css version on the version! so i'm NOT crazy! :-)
            well i'm not trying to spam here, but Gregiboy, thank you for the change... it burned perfectly it seems, going through it to verify the copy!
            FENGTAO ROX, and it only reaffirms why i bought this prog in the first place!
              Originally posted by AlienX69 View Post
              EDIT: !!!!! Please post any issues regarding NEW release DVD's that you think 6.1.2.5 is not decrypting properly !!!!!
              OK folks I'm here to report that the PROBLEM BEAST "Transformers 2 - Revenge of the Fallen" is NO LONGER an issue for creating a "Full Disc" backup with DVDFab 6.1.2.5
              IMPORTANT:
              Be sure to go back and review your PathPlayer setting (the Green Check, top right). Make sure it is set back to "Enable PathPlayer when necessary".
              Then try "Full Disc" mode. I was very impressed with the latest results, here is a view of the files after it completed:
              Volume in drive M is AX_MOVIE3
              Volume Serial Number is 3B51-D440
              Directory of M:\FullDisc\TRANSFORMERS2_D1_VANILLA\VIDEO_TS
              10/27/2009 06:04 PM <DIR> .
              10/27/2009 06:04 PM <DIR> ..
              10/27/2009 06:02 PM 30,720 VIDEO_TS.BUP
              10/27/2009 06:02 PM 30,720 VIDEO_TS.IFO
              10/27/2009 06:02 PM 913,408 VIDEO_TS.VOB
              10/27/2009 06:02 PM 18,432 VTS_01_0.BUP
              10/27/2009 06:02 PM 18,432 VTS_01_0.IFO
              10/27/2009 06:02 PM 524,288 VTS_01_0.VOB
              10/27/2009 06:02 PM 342,016 VTS_01_1.VOB
              10/27/2009 06:02 PM 14,336 VTS_02_0.BUP
              10/27/2009 06:02 PM 14,336 VTS_02_0.IFO
              10/27/2009 06:02 PM 14,336 VTS_02_1.VOB
              10/27/2009 06:02 PM 18,432 VTS_03_0.BUP
              10/27/2009 06:02 PM 18,432 VTS_03_0.IFO
              10/27/2009 06:02 PM 14,336 VTS_03_1.VOB
              10/27/2009 06:02 PM 20,480 VTS_04_0.BUP
              10/27/2009 06:02 PM 20,480 VTS_04_0.IFO
              10/27/2009 06:02 PM 14,336 VTS_04_1.VOB
              10/27/2009 06:02 PM 20,480 VTS_05_0.BUP
              10/27/2009 06:02 PM 20,480 VTS_05_0.IFO
              10/27/2009 06:02 PM 14,336 VTS_05_1.VOB
              10/27/2009 06:02 PM 22,528 VTS_06_0.BUP
              10/27/2009 06:02 PM 22,528 VTS_06_0.IFO
              10/27/2009 06:02 PM 14,336 VTS_06_1.VOB
              10/27/2009 06:02 PM 20,480 VTS_07_0.BUP
              10/27/2009 06:02 PM 20,480 VTS_07_0.IFO
              10/27/2009 06:02 PM 14,336 VTS_07_1.VOB
              10/27/2009 06:02 PM 114,688 VTS_08_0.BUP
              10/27/2009 06:02 PM 114,688 VTS_08_0.IFO
              10/27/2009 06:02 PM 94,263,296 VTS_08_0.VOB
              10/27/2009 06:02 PM 1,073,739,776 VTS_08_1.VOB
              10/27/2009 06:02 PM 1,073,739,776 VTS_08_2.VOB
              10/27/2009 06:02 PM 1,073,739,776 VTS_08_3.VOB
              10/27/2009 06:02 PM 1,073,739,776 VTS_08_4.VOB
              10/27/2009 06:02 PM 1,073,739,776 VTS_08_5.VOB
              10/27/2009 06:02 PM 1,073,739,776 VTS_08_6.VOB
              10/27/2009 06:02 PM 1,073,739,776 VTS_08_7.VOB
              10/27/2009 06:02 PM 402,237,440 VTS_08_8.VOB
              10/27/2009 06:02 PM 20,480 VTS_09_0.BUP
              10/27/2009 06:02 PM 20,480 VTS_09_0.IFO
              10/27/2009 06:02 PM 14,336 VTS_09_1.VOB
              10/27/2009 06:02 PM 20,480 VTS_10_0.BUP
              10/27/2009 06:02 PM 20,480 VTS_10_0.IFO
              10/27/2009 06:02 PM 14,336 VTS_10_1.VOB
              10/27/2009 06:02 PM 20,480 VTS_11_0.BUP
              10/27/2009 06:02 PM 20,480 VTS_11_0.IFO
              10/27/2009 06:02 PM 14,336 VTS_11_1.VOB
              10/27/2009 06:02 PM 22,528 VTS_12_0.BUP
              10/27/2009 06:02 PM 22,528 VTS_12_0.IFO
              10/27/2009 06:02 PM 14,336 VTS_12_1.VOB
              10/27/2009 06:02 PM 22,528 VTS_13_0.BUP
              10/27/2009 06:02 PM 22,528 VTS_13_0.IFO
              10/27/2009 06:02 PM 14,336 VTS_13_1.VOB
              10/27/2009 06:02 PM 18,432 VTS_14_0.BUP
              10/27/2009 06:02 PM 18,432 VTS_14_0.IFO
              10/27/2009 06:02 PM 20,162,560 VTS_14_0.VOB
              10/27/2009 06:02 PM 14,336 VTS_14_1.VOB
              56 File(s) 8,035,604,480 bytes
              2 Dir(s) 3,107,201,024 bytes free
              I did however do a little further cleanup with PgcEdit (PGC Editor/Blanking only, non-decrypton tool) as I'm a stickler on my final backups. I have a portable player that is sometimes a real pain if there is too much program chain jumping. Plus I like to change the program "First Play" order so that the MPAA plays first (if available), then it jumps directly to the movie and then the Menus when the movie is over. Plus PgcEdit has a very nice feature to remove ALL uncalled PGC's.
              PgcEdit is NOT needed for for you to get a Full Disc backup.
              REMEMBER: Turn PathPlayer back ON !!!
              Cheers,
              FYI: Tinker Bell next
              I have my set at "Always Enable". I haven't had a problem. So far so good.
                IMPORTANT:
                Actually Pathplayer should be set to Always Enabled as it works without issues that way and it is the Default setting for DVDFab as well.
                  You are 100% correct that Always Enabled is the Default mode, I set it to "Enable PathPlayer when necessary" as I do NOT use the "Jump To" feature. I use PgcEdit to do my final analysis of the ripped files, just my preference. "Enable PathPlayer when necessary" did work fine with T2 RotF, without having to restart .....
                  DVDFab will not enable PathPlayer in normal cases when opening a DVD. Once DVDFab detects a reading error when copying DVD, it will ask user to restart DVDFab to reopen the DVD using PathPlayer. In this way, DVDFab has the ability of opening DVD as fast as before, and uses PathPlayer when really necessary. If the reading error is encountered more than a minute or two into the copy process it will save time to use the default ("Always Enable") option below.
                  Always Enable PathPlayer (Default)
                  Improvements in PathPlayer and reductions in the scanning time have allowed this to become the default option. This option gives DVDFab the most information about your DVD and will usually result in a better, more reliable backup copy. You can still set the other two options (above) if desired. PathPlayer must be in this mode for the "Jump To..." navigation features to be active.
                  Cheers,
                  AX
                  The default Log File location: C:\Documents and Settings\"User Acct"\My Documents\DVDFab\Log
                    I have dvd fab 6.0.4.0 (updated in late July) is there a new version (6.1.2.5???) that I need??? I have tried to burn Transformers 2 and continually get a read message (Enable PathPlayer when necessary is checked). Any help????
                      Yes only 6.1.2.5 will work in "Full Disc" mode, DL the latest version.
                      Will only work if you have a DVDFab license, FREE version will not work !! Read the RED link in my sig
                      PS: Welcome to the forum !
                      AX
                        PathPlayer must be set to Always Enable.
                          Signals how do you explain this "my issue is different. I downloaded this version, installed it, rebooted, and when it tried to read TF2 disk, it gave me an error that says "to open the DVD disk buy or renew "dvd to dvd" wait for new version of dvdfab hd decrypter"
                          Is DVDFab no longer free? posted by mygiantcircle
                            Please read STICKY from Fengtao at top of DVD to DVD forum. It will answer your question.
                            Cheers!
                            Chris
                              @sa112263, I re-ripped it a second time to verify that I does work with "Enable as necessary" but do as signals suggest and try Always Enable. And be sure you have a LICENSED version of 6.1.2.5 !!!
                              As for the IMPORTANT ANNOUNCEMENT from Fengtao, I have a quick link to it in my sig if others want to view as well !!
                              AX
                                what happens to the program when the trial period is over ?
