DVD Ripper
Problem changing resolution and saving it!
When I try to change the AVI.default profile resolution and click on save, it resets to 720x552 and has done so for some time in numerous versions of 9.
You just release Version: 9.1.8.3. How exactly do I change default resolutions in AVI H264, so that every time DVDFab is loaded the ripper remembers it! I want 536x300 as the default!
This is actually a feature request, since Ripper adjusts the output size depending on the size/aspect ratio of the Source. As Ning noted, it has been passed to the developers. Do you have a special device that requires the 536x300 size you mentioned?
I am ripping a DVD collection of over 3,000 DVDS. I keep the size requirements down (to less than half of your default) by ripping at a quality that is visually acceptable to me. I keep having to use a version like 9.1.3.6 to achieve what I wish. I dislike the fact that alterations keep being made to restrict my use and force me to use older versions.
DVDFab v9.1.9.2 (OSX Version) and all previous version have been a hit and miss when changing the resolution to eg. 856x460, 856x372 unless the original is 640x480 then it does not get changed. I usually change the setting to high quality then using the mp4 setting I change the resolution from 720x305 and when I hit save it crashes. Sometimes the second try will work or it crashes again...then I just restart and leave the resolution alone.
