Problem Running Virtual Drive on X64
    I've installed the Viirtual Drive software under Windows XP 64bit, but the software will not launch, with Windows reporting that it is "not a valid 32bit application". The install puts it in Progran Files rather than Program Files (X86) so, it has been installed as a 64bit app. Anybody come across this ?
    Thanks.
    Try to redownload the setup and then reinstall.
    人生は贈り物であり、完全な喜びを経験する必要があります
      Yes, already tried that, and also downloaded the 1.1.1.4, which is exactly the same. Has this been tested under 64bit Windows XP,or just Vista/7 64 ??
        That is an somewhat unusual OS, no idea if it was tested with that or not. Flawless performance on all the w7 variants.
          @andyh01
          Thanks for your feedback, i will test in winxp 64 ASAP.
          DVDFab Virtual Drive will be install in program files in vista/win7, which is native x64 application.
          resigned
            Please try latest version 1116: http://forum.dvdfab.com/showthread.php?t=7699
            resigned
