High speed download doesn't work anymore
    Hello,
    since the new update the 2x speed doesn't work anymore, i'm stuck at 1.5x or 1x on disney+ with a fiber gigabit connection
    Speedtest are at 800 mbps
    Thanks !
    Which version are you using? In the future please choose a Prefix for your thread that shows the version.
      BTW, this is a new "feature" in 3.0.2.0, it just doesn't work correctly.
      I couldn't get over 1.5x when I was receiving 335Mbps (tested) down in my network on a file that was topping out un 6Mbps bitrate
        3.0.2.0 and the prefix doesn't work for the last release... and the gpu acceleration is enabled
          The prefix works, see your first post, I added it.
            Don’t do high speed on Disney.. they seem to notice that and you get flagged and blocked
              hi,
              The pc web speed is not equal to the pc access video site speed.
              The 3020 version will down to 0.5x and up to 1.5x speed.
              If the speed drop to 1x or below, It will auto change 2x speed after 3minutes.
              If it goes to 1.5x, may not be update if web or update. This will fix retry to 2x in next version.
              Disney web is most unstable for our test.
              yours,
              wilson
