This Notice is to alert you that the Spring Festival (Chinese New Year) Holiday is underway in China and much of Asia and for this reason the DVDFab Office will be closed until February 4. During this period, support by chat and email will not be available but the forum will be here for any problems you may encounter. Purchases of new products and license renewals may be made normally on the DVDFab website. Thanks for your understanding and Happy New Year!
Not all drives will work and DVDFab does not supply the text list of keys you will need to decrypt from the original disc, but UHD Copy and Ripper will work with content that is already decrypted and will work with original 4k UHD discs if 1) you have a supported ("friendly") drive, and 2) if the disc is one the list of supported titles that contains the keys, which again are not supplied by DVDFab but can be found on the internet. Hopefully the current situation can be improved.
Thanks for the reply, I had already seen the page, but doing a bit of research from the usual sellers are practically unavailable.
If you know sellers from whom you can buy them, you would do me a great favor.
Thanks, Roberto.
I bought my "friendly" one about 2 years ago on ebay from a guy in Spain. At that time, only the European firmware was "friendly" (the same model from US sellers would not work) , so it depends to some extent on where you are located. I would try ebay. I you can find one that works, do not update the firmware.
I have heard that there may be hacked 3rd party firmware available for some of the "unfriendly" drives that might make them work, so keep an eye out for that.
