Compress Size problem
    UHD Copy Compress Size problem
    For now I found this problem on 2 movie on main UHD and Full UHD
    1 Your Name 2016 2160p JPN UHD Blu-ray HEVC DTS-HD MA 5 1 and
    Kimi no na wa a.k.a. Your Name 2016 2160p HKG UHD Blu-ray HEVC DTS-HD MA 5 1
    main uhd 50G program show 45G after process done size = 23G and main uhd 25G Program show 23G after process done size = 16GB
    2 Arrival 2016 2160p UHD Blu-ray HEVC DTS-HD MA 7.1
    Arrial main uhd 50G program show 45G after process done size = 36G
    Thanks for the feedback, the developers will check it.
      The developers have reproduced the problem and are working on it. Sorry for the inconvenience. Watch the release notes for new versions, this thread may not be updated immediately.
        Any update?
        DVDFab x64 10.0.8.3 Beta still not fix?
          Any update?
          Your developer still solve this problem right?
          And Uhd creator have subtitle problem too.
            dvdfab 10.0.85 still have compress size problem.
            Try your name with uhd creator 100G conversion , source mkv 471G get output uhd 24G.
            Please increase video bitrate.
              Any update?
                Hello Gantz,
                I will check with the developers and get back to you. Thank you.
                Regards,
                Mona
                  found kingsman 2. source mkv 41G uhd, uhd creator 50G coversion get 23G.
                    Still have output size is undersized in UHD Creator on DVDFab x64 10.0.8.9
                    ==> kingsman 2. source mkv 41G bitrate 36003 kbps
                    DVDFab x64 10.0.8.8 uhd creator 50G, 100G coversion get 23G
                    DVDFab x64 10.0.8.9 uhd creator 50G coversion get 27G
                    DVDFab x64 10.0.8.9 uhd creator 100G coversion get 31G bitrate 27773kbps
                    ==> kingsman 2. source m2ts 41G (create by tsmuxer) DVDFab x64 10.0.8.9 uhd creator stall at 99%
                      Hi gantz,
                      The size problem has been worked on, please kindly wait for updates.
                      About the "99% stall" problem, some time is needed to download the source, thank you.
                      Regards,
                      Mona
