Slower FPS with "Direct render to video" when selected
    UHD Ripper Slower FPS with "Direct render to video" when selected
    Just installed a Nvidia 1050 into my system to start working with h265, and I have noticed that when I select "Direct render to video" in the subtitle mode it slows down the encoding to 8.5 to 9 FPS. Also lightning-shrink is not enabled and I only have h265 encoding enabled. When I use any other subtitle mode I can get 75 to 80 FPS, and lightning -shrink is enabled. Not sure if this is a setting I need to change or the lightning-shrink is not able to work with the "Direct render to video mode". any input would be great...Thanks...
    I have not seen any other reports of this, but that does not mean it is not happening. Please attach your fabcheck.log and a typical DVDFab internal log session where you have noticed this slowdown.
      Here is the internal log session, 1st is using the direct render and second is extract to. I will need some guidance on how to make a fabcheck.log
        Found it
          When "Direct render to video" option is selected, hardware accelerated video encoding can only be disabled, so processing speed will slow down if it's accelerated before.
          http://www.dvdfab.cn
            Thanks for the information, I always used Direct render to video for all forced subtitles. Will faster encoding be something that can be added in the future with Direct render to video option? Thanks.
