Using an LGWH16NS40 with Firmware version 1.02. The two titles listed both returned an error saying that the key isn't in the public database. However, they aren't recent titles so this seems strange. Could there be a problem on my end?
Arrival and Blade Runner 2046
Does the disc appear in (My) Computer? Can you select Open from the context menu and see the AACS, BDMV and CERTIFICATE folders and their contents? Pretty sure Blade Runner 2049 is supported, not sure about Arrival.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
it may be a couple days before dvdfab supports the discs - https://www.myce.com/news/dvdfab-ann...oftware-84041/
Rightyo. I've tried the last two UHD that I have in my collection (Thor Ragnarok and Star Wars: The Last Jedi) with exactly the same result, so I'm wondering if something else is up, but I'll give it a couple of days and try them all again. Perhaps a sticky list of disks that have been confirmed to work would be a good idea to save people bugging you about every disk.
Attach the DVDFab internal log if you receive this error again, thanks.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
All,
This may have been triggered by a server issue that has now been corrected, please try any problem discs again and report the results.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
