UHD Copy - remove unwanted audio tracks from UHD Bluray Full Disc copy
    Feature Request UHD Copy - remove unwanted audio tracks from UHD Bluray Full Disc copy
    Hi!
    Would it be possible to add the ability to remove unwanted audio tracks from the UHD Copy Full Disc module?
    I use it to compress UHD Blurays to 50gb Bluray, and I'd like to be able to save space removing some audio tracks, as I already do with the standard BD copy Full Disc module, where I compress 50gb blurays to 25gb ones.
    Thank you very much!
    Good suggestion, hope the devs can work on it if they are not already, I know that improvements are in the works for UHD Copy, Ripper and Creator. I am moving your thread to the UHD module forum. The devs assigned to UHD look there first.
      Thank you very much signals!
        A feature id also like to see to save some space for quality.
          It will be added in next new version 10093 beta, thanks!
            and why it does not work in 10093
              Please explain with detail. Thanks.
Name:	select wanted audio.png
              Regards,
              Mona
                Have a complete disc selected. However, the box for audio selection (see photo) is not selectable. Have tried this with several films.
