problem with UHD Copy on 4K 24 fps drives
    when you Copy UHD 4K drives with a speed of 24 fps 203 OPPO refuses to play
    and with 23.976 fps all plays
    here is a screenshot
      Please attach the DVDFab internal log session from one of these copies. Generally, the Copy module does not change the frame rate. If you have MediaInfo or BD Info, please analyze the one that will not play and attach the text output to a post. Instructions for attaching text or images are linked in my sig, below. We prefer attached images so that the forum record of the problem will be self-contained for future users that may read it.
      The message you received is produced by most players due to a disc read error. ??
        rock from here.
        here is BD Info what happened.
        Disc Title: Escape.From.New.York.1981.2160p.UHD.BluRay.HDR.HEV C.DTS-HD.MA.5.1-HDBEE
        Disc Size: 49,855,602,818 bytes
        Protection: AACS2
        BD-Java: No
        Extras: Ultra HD
        BDInfo: 0.5.8.7 (compatible layout created by DVDFab 11.0.0.5)
        Notes:
        BDINFO HOME:
        Cinema Squid (original standalone tool)
        DVDFab
        INCLUDES FORUMS REPORT FOR:
        AVS Forum Blu-ray Audio and Video Specifications Thread
        PLAYLIST: 00000.MPLS
        <--- BEGIN FORUMS PASTE --->
        Code:
        Total   Video
        Title                                                           Codec   Length   Movie Size      Disc Size       Bitrate Bitrate Main Audio Track                          Secondary Audio Track
        00000.MPLS                                                      HEVC    1:39:10  49,790,957,568  49,855,602,818  66.94   50.92   DTS-HD Master 5.1
        Code:
        DISC INFO:
        Disc Title:     Escape.From.New.York.1981.2160p.UHD.BluRay.HDR.HEVC.DTS-HD.MA.5.1-HDBEE
        Protection:     AACS2
        BD-Java:        No
        Extras:         Ultra HD
        PLAYLIST REPORT:
        Length:                 1:39:10.333 (h:m:s.ms)
        Total Bitrate:          66.94 Mbps
        (*) Indicates included stream hidden by this playlist.
        VIDEO:
        Codec                   Bitrate             Description
        MPEG-H HEVC Video       50919 kbps          2160p / 24 fps / 16:9 / Main 10 Profile 5.1 High / 4:2:0 / 10 bits / HDR / BT.2020 /
        * MPEG-H HEVC Video     8975 kbps           1080p / 24 fps / 16:9 / Main 10 Profile 5.1 High / 4:2:0 / 10 bits / Dolby Vision / BT.2020 /
        AUDIO:
        Codec                           Language        Bitrate         Description
        DTS-HD Master Audio             English         3885 kbps       5.1 / 48 kHz / 3885 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
        SUBTITLES:
        Presentation Graphics           Russian         22.152 kbps
        Presentation Graphics           Russian         27.68 kbps
        FILES:
        Name            Time In         Length          Size            Total Bitrate
        00004.M2TS      0:00:00.000     1:39:10.333     49,790,957,568  66,942 kbps
        CHAPTERS:
        Number          Time In         Length          Avg Video Rate  Max 1-Sec Rate  Max 1-Sec Time  Max 5-Sec Rate  Max 5-Sec Time  Max 10Sec Rate  Max 10Sec Time  Avg Frame Size  Max Frame Size  Max Frame Time
        1               0:00:00.000     0:09:02.958     37,689 kbps     73,636 kbps     0:05:23.375     62,574 kbps     0:08:10.500     61,018 kbps     0:08:13.041     196,300 bytes   783,038 bytes   0:00:22.000
        2               0:09:02.958     0:08:25.333     55,025 kbps     80,397 kbps     0:12:39.375     63,343 kbps     0:12:34.041     62,300 kbps     0:12:40.041     286,590 bytes   890,819 bytes   0:12:38.833
        3               0:17:28.291     0:06:52.291     57,718 kbps     74,686 kbps     0:19:09.791     61,878 kbps     0:19:13.458     60,625 kbps     0:19:18.333     300,616 bytes   781,908 bytes   0:19:09.083
        4               0:24:20.583     0:08:22.375     55,016 kbps     72,111 kbps     0:25:57.791     62,553 kbps     0:27:24.291     60,909 kbps     0:25:40.583     286,592 bytes   812,801 bytes   0:25:10.916
        5               0:32:42.958     0:07:28.458     47,586 kbps     64,338 kbps     0:35:48.708     60,516 kbps     0:40:08.208     57,059 kbps     0:35:52.791     247,798 bytes   563,467 bytes   0:40:03.666
        6               0:40:11.416     0:11:35.208     51,215 kbps     75,277 kbps     0:45:06.833     62,622 kbps     0:46:16.166     59,892 kbps     0:44:01.833     266,745 bytes   634,504 bytes   0:49:36.750
        7               0:51:46.625     0:08:24.583     56,698 kbps     76,651 kbps     0:58:16.333     62,544 kbps     0:55:42.333     60,879 kbps     0:55:47.125     295,302 bytes   728,523 bytes   0:58:15.666
        8               1:00:11.208     0:13:50.499     49,826 kbps     71,900 kbps     1:09:30.416     62,904 kbps     1:08:06.000     61,256 kbps     1:12:42.708     259,511 bytes   713,715 bytes   1:09:29.500
        9               1:14:01.708     0:04:22.791     44,861 kbps     71,340 kbps     1:15:48.458     61,897 kbps     1:17:15.750     58,757 kbps     1:17:55.458     233,655 bytes   771,737 bytes   1:15:47.458
        10              1:18:24.500     0:15:20.833     60,756 kbps     75,217 kbps     1:25:59.250     62,753 kbps     1:25:59.208     61,360 kbps     1:21:48.833     316,438 bytes   832,022 bytes   1:23:23.000
        11              1:33:45.333     0:01:02.708     61,596 kbps     61,774 kbps     1:34:11.416     59,687 kbps     1:34:26.833     59,259 kbps     1:34:26.541     320,812 bytes   636,182 bytes   1:34:28.000
        12              1:34:48.041     0:04:22.291     18,081 kbps     38,998 kbps     1:38:49.208     37,716 kbps     1:38:49.750     34,978 kbps     1:38:51.666     94,172 bytes    429,258 bytes   1:38:48.000
        STREAM DIAGNOSTICS:
        File            PID             Type            Codec           Language                Seconds                 Bitrate                 Bytes           Packets
        00004.M2TS      4113 (0x1011)   0x24            HEVC                                    5950.29                 50918.8                 37,872,728,667  205,913,888
        00004.M2TS      4117 (0x1015)   0x24            HEVC                                    5950.29                 8974.7                  6,675,263,296   36,362,037
        00004.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           5947.34                 3884.72                 2,887,969,776   16,619,776
        00004.M2TS      4768 (0x12A0)   0x90            PGS             rus (Russian)           5950.29                 22.152                  16,476,409      93,391
        00004.M2TS      4769 (0x12A1)   0x90            PGS             rus (Russian)           5950.29                 27.68                   20,588,311      115,978
        <---- END FORUMS PASTE ---->
        QUICK SUMMARY:
        Protection: AACS2
        BD-Java: No
        Playlist: 00000.MPLS
        Length: 1:39:10.333
        Video: MPEG-H HEVC Video / 50919 kbps / 2160p / 24 fps / 16:9 / Main 10 Profile 5.1 High / 4:2:0 / 10 bits / HDR / BT.2020 /
        Video: * MPEG-H HEVC Video / 8975 kbps / 1080p / 24 fps / 16:9 / Main 10 Profile 5.1 High / 4:2:0 / 10 bits / Dolby Vision / BT.2020 /
        Audio: English / DTS-HD Master Audio / 5.1 / 48 kHz / 3885 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
        Subtitle: Russian / 22.152 kbps
        Subtitle: Russian / 27.68 kbps
          original shows.
