Cliffhanger and UHDcop 11.0.0.7
    After trieing to copy to 50 GB Disc. Movie doesnt start on Bd Player Ub 900
    Please confirm whether the burnt copy can played on your PC or not.
    Also, when you tried to play it using Player Ub 900, what's the phenomenon? The player can recognize the disc, but cannot start it? Do you get any error? Please offer us more info. Thank you.
    Did you try burn other movies? Same problem?
      The player reads in and then stops. Disc will not play. No problems with other discs. At the Pc the film runs with dvdfab / vcl
        I have exactly the same problem with Panasonic UHD players, burned at least 15 UHDs to a 50GB Disc, and the result is exactly as described above.
        Examples Films UHDs:
        "Cliffhanger"
        "Dark Phoenix"
        "Zombieland" Sony
        "It: Chapter Two"
        "Angel Has Fallen"
        "Universal Soldier" (1992)
        "Léon" (1994)
        "Hellboy - Call Of Darkness"
        "Cold Pursuit"
        "Robin Hood" (2018)
        "Pet Sematary" (1989)
        "The Patriot" (2000) Sony
        "Sicario: Day of the Soldado"
        "Only The Brave" (2017)
        and a few others...
        4K Copy protection (Cinavia) was not removed correctly?
        Latest version "DVDFab 11.0.8.4" I use!
          Not sure all of these have Cinavia, please attach the DVDFab internal log session for some of them, instructions for this can be found here: https://forum.dvdfab.cn/forum/softwa...532#post263532
          DvdFab v11.0.8.4 has only been available a few hours, fail to see how you could test all of the above list in so short a time. Attach the log as requested above.
            It's the same with me.
            @Admin: "internal log session" I will submit later.
              Thanks, put it in this thread.
                Bei verschiedenen UHDs funktioniert es einfach nicht. War das das eigentliche Problem?
                ^^ Hier Beispiel UHD "Cliffhanger" Anhang << "Interne Protokollsitzung" ^^
                  Currently just tried, FLASH GORDON (Studiocanal) is absolutely not running, maybe new copy protection?
                    This is a really old thread, please start a new one and post the dvdfab_internal log file, thank you.
