Dolby Vision Roku TV compatibility
    My TV (TCL 55S515) does not play Dolby Vision files converted via the Dolby Vision MP4 profile. It just defects it as audio and doesn't even play the audio, just a scratching noise every couple of minutes. Here is MediaInfo of Dolby Vision files that do work:
    Video ID : 33 (0x21) Menu ID : 2 (0x2) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5@Main HDR format : Dolby Vision, Version 1.0, dvhe.04.06, BL+EL+RPU Codec ID : 36 Duration : 1 min 19 s Bit rate : 29.6 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.149 Stream size : 282 MiB (92%)
    Video ID : 33 (0x21) Menu ID : 2 (0x2) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5@Main HDR format : Dolby Vision, Version 1.0, dvhe.04.06, BL+EL+RPU Codec ID : 36 Duration : 1 min 14 s Bit rate : 30.3 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.152 Stream size : 269 MiB (92%)
    Code:
    Complete name                            : F:\Demos\Dolby OnOff.ts
    Format                                   : MPEG-TS
    File size                                : 678 MiB
    Duration                                 : 2 min 17 s
    Overall bit rate mode                    : Constant
    Overall bit rate                         : 41.5 Mb/s
    Video
    Menu ID                                  : 2 (0x2)
    Format                                   : HEVC
    Format profile                           : Main 10@L5.1@Main
    HDR format                               : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU
    Codec ID                                 : 36
    Bit rate                                 : 38.9 Mb/s
    Color space                              : YUV
    Bit depth                                : 10 bits
    Bits/(Pixel*Frame)                       : 0.196
    Stream size                              : 636 MiB (94%)
    Audio
    Menu ID                                  : 2 (0x2)
    Format                                   : E-AC-3 JOC
    Format/Info                              : Enhanced AC-3 with Joint Object Coding
    Commercial name                          : Dolby Digital Plus with Dolby Atmos
    Codec ID                                 : 135
    Duration                                 : 2 min 16 s
    Bit rate mode                            : Constant
    Bit rate                                 : 504 kb/s
    Channel(s)                               : 6 channels
    Channel layout                           : L R C LFE Ls Rs
    Sampling rate                            : 48.0 kHz
    Frame rate                               : 31.250 FPS (1536 SPF)
    Compression mode                         : Lossy
    Stream size                              : 8.20 MiB (1%)
    Service kind                             : Complete Main
    Complexity index                         : 16
    Number of dynamic objects                : 15
    Bed channel count                        : 1 channel
    Bed channel configuration                : LFE
    Complete name                            : F:\Demos\food.60.dm1_U30000_mz.ts
    Format                                   : MPEG-TS
    File size                                : 287 MiB
    Duration                                 : 1 min 16 s
    Overall bit rate                         : 31.6 Mb/s
    Video
    Menu ID                                  : 2 (0x2)
    Format                                   : HEVC
    Codec ID                                 : 36
    Bit rate                                 : 29.4 Mb/s
    Frame rate                               : 60.000 FPS
    Color space                              : YUV
    Bit depth                                : 10 bits
    Bits/(Pixel*Frame)                       : 0.059
    Stream size                              : 266 MiB (93%)
    Audio
    Menu ID                                  : 2 (0x2)
    Format                                   : E-AC-3 JOC
    Codec ID                                 : 135
    Duration                                 : 1 min 15 s
    Bit rate                                 : 640 kb/s
    Stream size                              : 5.77 MiB (2%)
    General
    Complete name                            : F:\Demos\NASA (Dolby Vision).mp4
    Format                                   : MPEG-4
    Format profile                           : Base Media / Version 2
    Codec ID                                 : mp42 (mp42/dby1/isom)
    File size                                : 510 MiB
    Duration                                 : 2 min 23 s
    Overall bit rate                         : 29.9 Mb/s
    Encoded date                             : UTC 2017-04-13 22:51:30
    Tagged date                              : UTC 2017-04-13 22:51:30
    Video
    Format                                   : HEVC
    HDR format                               : Dolby Vision, Version 1.0, dvhe.05.09, BL+RPU
    Codec ID                                 : dvhe
    Codec ID/Info                            : High Efficiency Video Coding with Dolby Vision
    Bit rate                                 : 29.3 Mb/s
    Frame rate mode                          : Constant
    Frame rate                               : 59.940 (60000/1001) FPS
    Color space                              : YUV
    Bit depth                                : 10 bits
    Stream size                              : 499 MiB (98%)
    Codec configuration box                  : hvcC+dvcC
    Audio
    Format                                   : E-AC-3 JOC
    Codec ID                                 : ec-3
    Duration                                 : 2 min 22 s
    Bit rate                                 : 640 kb/s
    Bit depth                                : 16 bits
    Stream size                              : 10.9 MiB (2%)
    Complexity index                         : 14
    Number of dynamic objects                : 13
    This sample video someone on Reddit uploaded also works, though with no audio.
    Code:
    General
    Complete name                            : F:\Batman vs. Superman_Dolby Vision Demo.m2ts
    Format                                   : BDAV
    Format/Info                              : Blu-ray Video
    File size                                : 449 MiB
    Duration                                 : 2 min 20 s
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 26.8 Mb/s
    Video
    Menu ID                                  : 2 (0x2)
    Format                                   : HEVC
    Codec ID                                 : 36
    Duration                                 : 2 min 21 s
    Bit rate                                 : 25.1 Mb/s
    Color space                              : YUV
    Bit depth                                : 10 bits
    Bits/(Pixel*Frame)                       : 0.126
    Stream size                              : 422 MiB (94%)
    Audio
    Menu ID                                  : 2 (0x2)
    Format                                   : E-AC-3 JOC
    Codec ID                                 : 6
    Bit rate                                 : 640 kb/s
    Delay relative to video                  : -486 ms
    Stream size                              : 10.7 MiB (2%)
    Language                                 : French
    Complexity index                         : 12
    Number of dynamic objects                : 11
    Is there any way to get a Blu-ray or REMUX from a Blu-ray in a format I can watch on my TV with Dolby Vision?
    Moved your thread to the correct forum. It is preferred that you attach any information you are submitting as a text file rather than placing it in the message area. The attachments are easier for the developers to obtain and share if necessary, so please attach in future posts. If you have the MediaInfo for one of the files that does NOT work, please attach that and the DVDFab internal log. Tips for attachments: http://forum.dvdfab.cn/showpost.php?...40&postcount=5
      I figured it out, it was just that my TV only plays profile 5 as is listed in the Dolby Vision profiles document: https://www.dolby.com/us/en/technolo...els_v1.3.1.pdf. Things encoded in DV profile 5 play fine.
