Audio Sync Issue
    Audio Sync Issue
    I have been trying to use the UHD Ripper software to pull the TrueHD audio off of two different movies. The TrueHD track has audio sync issues, but the other tracks ac3 are fine. The two movies that have this track are Forrest Gump and Braveheart. I am able to play the video and the audio on the TrueHD is working fine on the source. I was able to use a different software to pull the audio track off so it must be in the UHD Ripper software.
    braveheart need to adjust delay
      electro Please attach the DVDFab internal log session from the attempt of FGump or Braveheart. If you are extracting the audio, how can you tell there is a sync problem? Sync to which video? Is this sync error the same throughout the movie, or becomes worse near the end?
