2176p issue
    UHD Copy 2176p issue
    It is my understanding that the GTX-1050 (10xx series) card is 32x32, which means that a 3840x2160 copy becomes 3840x2176, as 2176 is a multiple of 32. I also understand that a turing card is required to get 2160, as it supports 16x16. For example the RTX-2060. What is DVDfab's official response regarding the 2176 issue?
    The office is currently closed for the Chinese Spring Festival official holiday, so there will be nothing ‘official’ until after that. It probably does not matter unless you are compressing or converting the content.
      I indeed will be copying to either BD50 or BD25.
        I just found out that the GTX-1660 is also a turing card, and cheaper than the RTX series.
