After upgrade firmware of intel hd630 graphic card, uhd conversion failed
    UHD Converter After upgrade firmware of intel hd630 graphic card, uhd conversion failed
    Hi, I have a MKV video file containing DOLBY VISION with around 55gb in size, DVD Fab refused and aborted the UHD conversion totally after I have upgraded my Intel HD630 graphic card to the latest version bearing version No. 27.20.100.8190 dated 5/5/2020 and prior to that I have been using the outdated firmware version way back in the year 2016 and with the older version firmware, DVDfab will convert the UHD Video in HDR mode correctly but the output for DOLBY VISION mode will either have correct output colour for some MKV file or in BLACK AND WHITE COLOUR for some other MKV files. Can anyone tell me what is the problem after the upgrade of the graphic card and why some conversion of MKV file in DOLBY VISION mode is in black and white colour? According to the Intel website, the latest firmware for this graphic card support DOLBY VISION for this graphic card and latest version also support the AI Enlarger mode. I have been using this software to convert MKV UHD file to UHD Bluray format to play on a UHD Bluray player. Thank you for your reply! .
    All posts regarding UHD content should go in that forum, I will move your thread. Note that converting downloaded files may be problematic due to unknown authoring, which makes reproducing the problem difficult or impossible. The developers will need to check it. You may wish to revert to the older driver temporarily.
      Thank you!
        Sir, the Media info of the MKV file is as follows, is there any problem for DVDFAB to convert this kind MKV file with the latest intel HD630 driver or older driver in DOLBY VISION mode? very appreciated if you reply : -
        Video #1
        ID in the original source medium : 4113 (0x1011)
        Format : HEVC
        Format/Info : High Efficiency Video Coding
        Format profile : Main 10@L5.1@High
        HDR format : SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
        Codec ID : V_MPEGH/ISO/HEVC
        Duration : 1 h 48 min
        Bit rate : 59.9 Mb/s
        Width : 3 840 pixels
        Height : 2 160 pixels
        Display aspect ratio : 16:9
        Frame rate mode : Constant
        Frame rate : 23.976 (24000/1001) FPS
        Color space : YUV
        Chroma subsampling : 4:2:0 (Type 2)
        Bit depth : 10 bits
        Bits/(Pixel*Frame) : 0.301
        Stream size : 45.6 GiB (83%)
        Title : Birds.of.Prey.2020.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT
        Language : English
        Default : Yes
        Forced : No
        Color range : Limited
        Color primaries : BT.2020
        Transfer characteristics : PQ
        Matrix coefficients : BT.2020 non-constant
        Mastering display color primaries : BT.2020
        Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
        Maximum Content Light Level : 683 cd/m2
        Maximum Frame-Average Light Level : 136 cd/m2
        Original source medium : Blu-ray
        Video #2
        ID in the original source medium : 4117 (0x1015)
        Format : HEVC
        HDR format : SMPTE ST 2086, HDR10 compatible
        Bit rate : 63.3 kb/s
        Width : 1 920 pixels
        Height : 1 080 pixels
        Color space : YUV
        Bit depth : 10 bits
        Bits/(Pixel*Frame) : 0.001
        Stream size : 49.3 MiB (0%)
        Language : English
        Default : No
        Forced : No
        Audio #1
        ID in the original source medium : 4352 (0x1100)
        Format : MLP FBA 16-ch
        Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
        Commercial name : Dolby TrueHD with Dolby Atmos
        Codec ID : A_TRUEHD
        Bit rate mode : Variable
        Bit rate : 3 686 kb/s
        Maximum bit rate : 6 912 kb/s
        Channel(s) : 8 channels
        Channel layout : L R C LFE Ls Rs Lb Rb
        Sampling rate : 48.0 kHz
        Frame rate : 1 200.000 FPS (40 SPF)
        Compression mode : Lossless
        Stream size : 2.80 GiB (5%)
        Language : English
        Default : Yes
        Forced : No
        Number of dynamic objects : 15
        Bed channel count : 1 channel
        Bed channel configuration : LFE
        Audio #2
        Format : DTS XLL
        Format/Info : Digital Theater Systems
        Commercial name : DTS-HD Master Audio
        Codec ID : A_DTS
        Bit rate : 4 251 kb/s
        Channel layout : C L R LFE Lb Rb Lss Rss
        Frame rate : 93.750 FPS (512 SPF)
        Bit depth : 24 bits
        Stream size : 3.23 GiB (6%)
        Language : English
        Default : No
        Forced : No
        Audio #3
        Format : AC-3
        Format/Info : Audio Coding 3
        Commercial name : Dolby Digital
        Codec ID : A_AC3
        Bit rate mode : Constant
        Bit rate : 640 kb/s
        Channel(s) : 6 channels
        Frame rate : 31.250 FPS (1536 SPF)
        Bit depth : 16 bits
        Compression mode : Lossy
        Stream size : 499 MiB (1%)
        Language : English
        Service kind : Complete Main
        Default : No
        Forced : No
        Audio #4
        ID in the original source medium : 4353 (0x1101)
        Format : AC-3
        Codec ID : A_AC3
        Bit rate : 448 kb/s
        Bit depth : 16 bits
        Stream size : 349 MiB (1%)
        Language : English
        Default : No
        Forced : No
        Audio #5
        ID in the original source medium : 4354 (0x1102)
        Format : AC-3
        Codec ID : A_AC3
        Bit rate : 448 kb/s
        Bit depth : 16 bits
        Language : English
        Default : No
        Forced : No
        Audio #6
        ID in the original source medium : 4355 (0x1103)
        Format : AC-3
        Codec ID : A_AC3
        Bit rate : 448 kb/s
        Bit depth : 16 bits
        Language : French
        Default : No
        Forced : No
        Audio #7
        ID in the original source medium : 4356 (0x1104)
        Format : AC-3
        Codec ID : A_AC3
        Bit rate : 448 kb/s
        Bit depth : 16 bits
        Language : Spanish
        Default : No
        Forced : No
        Audio #8
        ID in the original source medium : 4357 (0x1105)
        Format : AC-3
        Codec ID : A_AC3
        Bit rate : 448 kb/s
        Bit depth : 16 bits
        Language : Czech
        Default : No
        Forced : No
        Audio #9
        ID in the original source medium : 4358 (0x1106)
        Format : AC-3
        Codec ID : A_AC3
        Bit rate : 448 kb/s
        Bit depth : 16 bits
        Language : Hindi
        Default : No
        Forced : No
        Audio #10
        ID in the original source medium : 4359 (0x1107)
        Format : AC-3
        Codec ID : A_AC3
        Bit rate : 448 kb/s
        Bit depth : 16 bits
        Language : Polish
        Default : No
        Forced : No
        Text #1
        Format : UTF-8
        Codec ID : S_TEXT/UTF8
        Codec ID/Info : UTF-8 Plain Text
        Bit rate : 60 b/s
        Count of elements : 1677
        Stream size : 47.7 KiB (0%)
        Title : English-SRT
        Language : English
        Default : Yes
        Forced : No
        Text #2
        ID in the original source medium : 4768 (0x12A0)
        Format : PGS
        Muxing mode : zlib
        Codec ID : S_HDMV/PGS
        Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
        Bit rate : 43.7 kb/s
        Count of elements : 3876
        Stream size : 33.9 MiB (0%)
        Title : English-PGS
        Language : English
        Default : No
        Forced : No
        Text #3
        ID in the original source medium : 4769 (0x12A1)
        Format : PGS
        Muxing mode : zlib
        Bit rate : 27.3 kb/s
        Count of elements : 2854
        Stream size : 21.2 MiB (0%)
        Title : French-PGS
        Language : French
        Default : No
        Forced : No
        Text #4
        ID in the original source medium : 4770 (0x12A2)
        Format : PGS
        Muxing mode : zlib
        Bit rate : 28.4 kb/s
        Count of elements : 2786
        Stream size : 22.0 MiB (0%)
        Title : Chinese-PGS
        Language : Chinese
        Default : No
        Forced : No
        Text #5
        ID in the original source medium : 4771 (0x12A3)
        Format : PGS
        Muxing mode : zlib
        Bit rate : 28.5 kb/s
        Count of elements : 2926
        Stream size : 22.1 MiB (0%)
        Title : Chinese-PGS
        Language : Chinese
        Default : No
        Forced : No
        Text #6
        ID in the original source medium : 4772 (0x12A4)
        Format : PGS
        Muxing mode : zlib
        Bit rate : 18.4 kb/s
        Count of elements : 2848
        Stream size : 14.3 MiB (0%)
        Title : Korean-PGS
        Language : Korean
        Default : No
        Forced : No
        Text #7
        ID in the original source medium : 4773 (0x12A5)
        Format : PGS
        Muxing mode : zlib
        Bit rate : 32.8 kb/s
        Stream size : 25.4 MiB (0%)
        Title : Spanish-PGS
        Language : Spanish
        Default : No
        Forced : No
        Text #8
        ID in the original source medium : 4774 (0x12A6)
        Format : PGS
        Muxing mode : zlib
        Count of elements : 3012
        Stream size : 14.2 MiB (0%)
        Title : Arabic-PGS
        Language : Arabic
        Default : No
        Forced : No
        Text #9
        ID in the original source medium : 4775 (0x12A7)
        Format : PGS
        Muxing mode : zlib
        Bit rate : 29.5 kb/s
        Count of elements : 2922
        Stream size : 22.9 MiB (0%)
        Title : Czech-PGS
        Language : Czech
        Default : No
        Forced : No
        Text #10
        ID in the original source medium : 4776 (0x12A8)
        Format : PGS
        Muxing mode : zlib
        Bit rate : 27.6 kb/s
        Count of elements : 2772
        Stream size : 21.3 MiB (0%)
        Title : Polish-PGS
        Language : Polish
        Default : No
        Forced : No
        Text #11
        ID in the original source medium : 4777 (0x12A9)
        Format : PGS
        Muxing mode : zlib
        Duration : 1 h 39 min
        Bit rate : 1 077 b/s
        Count of elements : 70
        Stream size : 787 KiB (0%)
        Title : French-FORCED-PGS
        Language : French
        Default : No
        Forced : No
        Text #12
        ID in the original source medium : 4778 (0x12AA)
        Format : PGS
        Muxing mode : zlib
        Duration : 1 h 33 min
        Bit rate : 151 b/s
        Count of elements : 14
        Stream size : 104 KiB (0%)
        Title : Spanish-FORCED-PGS
        Language : Spanish
        Default : No
        Forced : No
        Text #13
        ID in the original source medium : 4779 (0x12AB)
        Format : PGS
        Muxing mode : zlib
        Duration : 1 h 41 min
        Bit rate : 1 131 b/s
        Count of elements : 94
        Stream size : 844 KiB (0%)
        Title : Czech-PGS
        Language : Czech
        Default : No
        Forced : No
        Text #14
        ID in the original source medium : 4780 (0x12AC)
        Format : PGS
        Muxing mode : zlib
        Duration : 1 h 47 min
        Bit rate : 789 b/s
        Count of elements : 102
        Stream size : 623 KiB (0%)
        Title : Hindi-FORCED-PGS
        Language : Hindi
        Default : No
        Forced : No
        Menu
        00:00:00.000 : en:Chapter 01
        00:08:08.446 : en:Chapter 02
        00:17:53.739 : en:Chapter 03
        00:27:11.838 : en:Chapter 04
        00:35:40.805 : en:Chapter 05
        00:44:48.268 : en:Chapter 06
        00:53:43.386 : en:Chapter 07
        01:01:15.296 : en:Chapter 08
        01:10:55.960 : en:Chapter 09
        01:19:06.158 : en:Chapter 10
        01:24:28.146 : en:Chapter 11
        01:34:27.620 : en:Chapter 12
        01:41:26.997 : en:Chapter 13
          Hello, we will need the log session for the conversion and a problematic source, please kindlly check PM, thank you.
