I just received it today as part of the lifetime deal - No display, connecting to a PC to attempt a reimage shows a 1.27 GB FAT32 partition with 56Kb in use, the image tool will not recognize it and allow me to burn it again.
Unit DOA
Contact service@dvdfab.com at once.Supplying DVDFab Logs in the Forum ...........................User Manual PDF for DVDFab v11................................ Guide: Using Images in Posts
Did you follow the doc to reinstall firmware? Also please check your TF card to make sure it works ok.DVDFab is the all-in-one software package for copying Blu-ray/DVD and converting video file.
http://www.dvdfab.cn
I was able to successfully reimage my Mini PC (VidonMe TV) by following the directions in the "Download Tutorial" http://vidon.me/download/how-to-rein....0-Mini-PC.zip
It took me a few tries before realizing that the instructions say to burn the image to a Micro SD Card, then insert the Micro SD Card into the Mini-PC (VidonME TV) and then turn it on and leave it alone for Ten Minutes while the Mini PC copies the the image from the Micro SD Card, to the Mini PC.
After following the instructions, the Mini PC was restored to Factory Condition and was exactly like it was the day I un-boxed it.
