DVDFab Forum - DRM Removal not working
  • #16
    Hi Mona. Thank-you for your reply. The two files are there. To make sure antivirus was disabled I uninstalled it; DRM removal still failed.
    • #17
      Here are packed (because my logs are bigger than allowed here).
      And also screen of a one file (last one) which has instead of few minutes over 95 minutes...
      As I see - DVDFab not ending converted track and playing next one, but playing next one randomly
      and saving into still one single file... This is the biggest problem...
      .:: Best Regards - Artur ::.
      • #18
        I have forwarded your feedback to our developers for checking.
        Regards,
        mona
        DVDFab log default location:
        For Windows: C:\Users\User Name\Documents\DVDFab11\Log
        For Mac: Finder>Documents>DVDFab11>Log
        DVDFab Player 5:
        For Windows: C:\Users\User Name\Documents\DVDFab Player 5\Log
        For Mac: Finder>Documents>DVDFab Player 5>Log
        Guide for adding attachments in a post
        --Please use attachment button to attach your most recent log files.
        • #19
          Regards,
          mona
          Thank-you for your time and efforts with this!
          • #20
            Hello krupers,
            We reproduce the problem, we will need some time to check it out. Thank you.
            Regards,
            mona
            DVDFab Player 5:
            • #21
              Hello krupers,
              Regards,
              mona
              Of course - thank you so much for everything. I am waiting
              • #22
                Hello,
                Please upgrade to DVDFab 10.0.7.8 and use DRM Removal to try again.
                Regards,
                mona
                DVDFab Player 5:
                • #23
                  Hello,
                  Regards,
                  mona
                  Dear Mona,
                  I don't see x64 version of DVDFab at this moment to download
                  Should I wait for this version or install x86 version in 10.0.7.8?
                  Regards,
                  Artur.
                  • #24
                    Hi krupers, look in here: https://forum.dvdfab.cn/forum/softwa...ish/dvdfab-x64
                    Supplying DMS Logs to Developers.............
                    • #25
                      Dear Mona,
                      Regards,
                      Artur.
                      Hello,
                      Please give x86 version of DVDFab 10.0.7.8 version a try first. Please kindly update, thank you.
                      Regards,
                      mona
                      DVDFab Player 5:
                      • #26
                        I already checked and I think I have to wait for 10.0.7.8 x64
                        Hello,
                        Regards,
                        mona
                        YASS! Newest x86 version od DRM Removal finally works with newest iTunes perfectly.
                        Thank you, thank you soooooooo much!!!!
                        Question 1: What was the problem it didn't worked earlier? O.o
                        Question 2: When you release x64 version it will also work or only x86 is required?
                        Greetings,
                        Artur.
                        • #27
                          Hello,
                          Regards,
                          mona
                          Hello Mona. I tried this newer version but am still not having any success with the DRM removal loading the file from Windows. Should I also try the x64 version like Krupers did? Thank-you!
                          • #28
                            Update--the current x64 version did not work either. :-(
                            • #29
                              --When a song was stopped before it completed a playback and you loaded it as source for the conversion, which was when this problem happened. It shall not happen again.
                              --The fix will be included in new versions of x64 as well.
                              Regards,
                              mona
                              DVDFab Player 5:
                              • #30
                                Hello,
                                Please do a complete uninstall of DVDFab, and then download the latest one from http://www.dvdfab.cn/download.htm to try again.
                                If still have problem, please post the latest drm and dvdfab_internal.log file, and post a screenshot about the problem.
                                Regards,
                                mona
                                DVDFab Player 5:
