DVDFab Forum - Trouble uploading ST Deep Space Nine metadata
instagram takipci satin al - instagram takipci satin al mobil odeme - takipci satin al
bahis siteleri - deneme bonusu - casino siteleri
bahis siteleri - kacak bahis - canli bahis
goldenbahis - makrobet - cepbahis
cratosslot - cratosslot giris - cratosslot
istanbul escort - çapa escort - şirinevler escort - avcılar escort - şişli escort - avrupa yakası escort - şirinevler escort - halkalı escort - beylikdüzü escort - mecidiyeköy escort - ümraniye escort - adana escort malatya escort
film izle - film izle
    When I try to enter the metadata of the disc 5 of the Star Trek Deep Space Nine season 2 DVD boxset.
    The system says the upload was successful.
    But when I reopen the DVD, the metadata is gone.
    I can reenter it again and again it says that it was successful.
    I can keep doing this forever.
    Hello,
    Is spaceharfang the user name used for the meta uploading?
    Please confirm whether you have this problem with other movie sources or not.
    Also, zip the folder "DVDFabCommon" and upload it here. You can find it under: C:\Users\xxxx\Documents\DVDFabCommon
    Regards,
    Mona
      My contributor username is "cyberharfang". My license is under an email that is not accepted on the forum.
      I just tried to upload of an Andromeda season 1 dvd and it did the same thing after a DVDFab restart.
        Thank you for the info. I have passed the info to the developers for checking.
        Regards,
        Mona
          Hello,
          Please upgrade to DVDFab 10.0.8.5 Beta version to try again, we've fixed the metadata problem in this new version. Please have a try.
          Regards,
          Mona
            Just tried the x64 beta and uploaded the whole set.
            Everything worked perfectly.
              This is the closest thread I could find for problems uploading metadata. Although the metadata uploads, there are glitches and aggravations in the process.
              1, When submitting metadata information for upload; when finished, the information window does not automatically close and start the RIP process when the “Close” button is clicked, making it necessary to X out of the window to start the batch process.
              2. After submitting metadata information for the entire disk, a redundant pop-up appears for every file being ripped.
              3. The timer on the redundant pop-up sometimes stops, leaving the pop-up window hanging open and halting the batch process making it mandatory to monitor the entire batch process and close each window.
              4. It is not part on any problem, but I could upload more detailed information, like Producer, Director and synopsis obtained from the web, but there are no fields to provide that information. It is a suggestion that you provide fields for this information for those that would like to (Optionally) provide more detailed information. A field for optional remarks from the person uploading the information would be nice also. In my case, the release dates for the episode did not match the episode order on the disks. Also, a setting had to be changed to view and select all of the episodes on the discs. I’m sure notes on observances, problems and work arounds would be appreciated.
              Please: Once information is entered for the entire disc, no other pop-ups asking for information are needed. If you could pass this on to the development team I would appreciate it.
                Thank you for your feedback. I've passed it to our product manager.
                  Please start a new thread next time. I have had some trouble with meta uploads also recently.
