I feel like I have a setting turned off or something - or maybe I'm missing something obvious.
I understand that META INFO is used as a means of Plex and other tools to understand the name/title of the content.
However, I would expect that if I put a disc in and the disc has a meta info entry in the database that the TITLE on the main ripping screen would automatically populate instead of continuing to default to the CONVERSION->OUTPUT pattern setting.
No?
Despite the fact that Predator 2 has meta info in the database ... when I add the items to rip, I get the same generic Volume/Title Predator2.theatrical, etc.
These titles, BTW, end up as the meta data in Plex - so I essentially have to turn off Plex's local meta data scrapping because I'm not going to hand enter the titles for 30 items I'm ripping; which doesn't seem out of line if the meta info is sitting there available.
It doesn't make sense that meta info's selling point is to share this data, but then require the end user manually cut and paste, enter it themselves. So I have to assume I'm not using the feature correctly
Thanks for any enlightenment.
No?
